Old 02-19-2014, 05:35 PM   #1
charles nelson
Drives: red Liftback
Question When to do fluid changes?
I have a 2008 Yaris with auto trans. My Toyota dealer and the manual state that I should have major fluid change at 60,000 miles. I bring the vehicle in for an annual checkup. But I have not put any where near that mileage on the vehicle. Now that it is 6 model years old...should I insist that the trans and brake fluid along with the antifreeze be flushed and changed?
charles nelson is offline   Reply With Quote
Old 02-19-2014, 07:30 PM   #2
Klink10
Klink10's Avatar
I would at least do a antifreeze check-up based on where you are.
Old 02-19-2014, 08:30 PM   #3
nookandcrannycar
^^^^^ This. (other than oil/filter changes, the only fluid related thing I've done is (1x) add part of a bottle of coolant/anti-freeze)
Old 02-19-2014, 10:09 PM   #4
The Limo 2
The Toyota Canada Maintenance Menu states to change your automatic transmission fluid every 96,000 Km (60,000 miles), your Coolant at 128,000 Km (80,000 miles) and then every 64,000 Km (40,000 miles) after that.
I am not sure about the American Maintenance Menu but it is more lenient about changes than the the Toyota Canada Maintenance Menu.
Roy
The Limo 2 is offline   Reply With Quote
Old 02-20-2014, 02:48 AM   #5
john21031
Drives: '10 Fit Sport MT and 2012 Fit
At six years old, definitely get all the fluids changed. Brake fruid is known to absorb moisture and has to be changed every 2-3 yrs.
You don't want things getting corroded and further contaminated by old fluids. No question about it, change everything if you want your car to last.
john21031 is offline   Reply With Quote
Old 02-20-2014, 04:26 PM   #6
nookandcrannycar
Perhaps as an ideal, but what are the consequences if you don't (IMO, it's about reasonable prudence re safety combined with cost benefit)? I've driven well over 1 million miles (including 4 cars from new to over 150k miles) and I've never changed the brake fluid on any of them. IIRC, I've also never caused the rotors to need replacement nor resurfacing either. I think how a person drives and where they live/operate the vehicle = significant input re how much the above is needed to avoid significant consequences. Given the OP's location relative to either of ours, I think the OP might suffer 'dire consequences' before either of us would. If I lived where the OP does, and drove differently than I do, I might follow your recommendation.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
Smelly Wiper Fluid Tedtalker DIY / Maintenance / Service 15 08-30-2013 04:40 AM
change tranny fluid peewee1 DIY / Maintenance / Service 2 05-24-2013 09:30 AM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
