Old 02-23-2014, 04:06 AM   #1
mussie
Drives: yaris
[HELP] Dropped knife into centre console
Was pulling apart the centre console and dropped my knife into the part which falls into the middle panel which has the gears and handbrake. What do i need to undo the bolt on it ? just a torque wrench ? what happens if it fell further down is it a possible hazard?
thanks
mussie is offline   Reply With Quote
Old 02-23-2014, 05:36 AM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
In the center console, behind the e-brake, there should be a cup holder. If I remember correctly, you only need a screw driver. Once you remove the screw, you can lift the center plastic up. I don't see it causing any problems if kept there, but someone may find treasure if you ever sell the car =].
Edit: I changed the bolt into a screw for easier access. I just used a interchangeable wrench to take off the bolt.
MyzticZ3r0 is offline   Reply With Quote
Old 02-23-2014, 05:14 PM   #3
mussie
Drives: yaris
Undid the bolt and now have a problem lifting the plastic piece over the hand brake :P keeps getting hooked. any tips?
Old 02-23-2014, 05:34 PM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Gently lift its front end upwards.
Be careful not to break the clips - I'll cross my fingers ;)
Old 02-23-2014, 05:38 PM   #5
MyzticZ3r0
You have to unclip the smaller plastic piece near the ebrake - pop it out. Afterwards, you can raise the center plastic by the back and move the ebrake in position.
Old 02-23-2014, 08:39 PM   #6
mussie
Drives: yaris
DONE :D TY
