Old 02-23-2014, 06:35 AM   #1
Exalix
Drives: Yaris Trend VVTi 1,33 2014
Yaris 2013 tweeter, replaceable?
Has anyone tried to replace the tweeters?
http://imageshack.com/a/img577/8423/k4o3.png
Exalix is offline   Reply With Quote
Old 02-23-2014, 06:40 AM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
The C pillars are held in by clips - relatively easy to pull off. I would look into if your model has side airbags though - since you don't want to deploy them. Disconnect your battery and it should be fine. We do have the specialist, CTScott, where he knows practically everything on the Yaris. I'm sure he'll see your message soon and he'll reply =].
MyzticZ3r0 is offline   Reply With Quote
Old 03-01-2014, 02:36 AM   #3
mr_miles
Drives: 2013 Yaris
I have replaced mine! It's easy! the airbag shouldn't deploy - I don't think you could manage to hit the sensor hard enough, so dont be scurred (but feel free to unplug the battery anyhow, it's good practice). There is however a "you cant remove this" clip on there that i broke on both sides. it doesn't seem to affect the a-pillar being able to stay clipped in though as there's three other ones I believe haha.
I've gone through two sets of tweeters. first set were smaller than the OEM ones and I had to chop them out of their normal mounts to get them to work, they broke in about a month which was totally my fault. The set I'm using now were cheap ones i got on amazon or ebay - don't remember the brand but they blow the factory ones out of the water! they're about a mm larger in diameter than OEM, but they fit in the clip and are staying in place wonderfully.
Old 03-01-2014, 05:58 AM   #4
boooggy
Drives: 2014 Yaris lb 1.33L
hi there miles
can u please tell me whats the size of the tweeters?
thx in advance.
boooggy is offline   Reply With Quote
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
