Old 02-25-2014, 12:55 AM   #1
bairjo
Lift back pneumatic lifters
I have noticed that the pneumatic lifter joints on my hatch back are becomming a lot mor stiff and creaking more these days. Any suggestions on lube for these if i take them off..WD40? Anyone else notice this on their car?
Old 02-25-2014, 07:04 AM   #2
MadMax
MadMax's Avatar
Yep, happening to my 08 as well...
Old 02-25-2014, 07:13 AM   #3
The gas struts are affected by the cold and will not work as well when it is really cold.
You should not lubricate the shaft (particularly with WD40, which will destroy the seals). Gas struts have oil within them that both dampens them and self lubricates them. You can wipe off the shaft if it is dusty, but according to the manufacturers you should not lubricate them. The ball joints at the ends can and should be lubricated though.
Old 02-25-2014, 04:49 PM   #4
bairjo
Thank you. It does sound more like the ball joints at the ends. I'll lube them this weekend. Thanks again.
My yaris lift back SQ install cm_ls1 In Car Entertainment + Electronics (audio / video / alarm) 61 12-21-2010 11:39 AM
2008 S Lift Back k27 General Yaris / Vitz Discussion 6 09-16-2007 11:48 AM
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 10:04 PM
So we just came back from TRD Thailand... eTiMaGo Performance Modifications 28 03-21-2007 06:52 PM
back seat KSIbucky General Yaris / Vitz Discussion 10 05-30-2006 01:54 PM
