Old 02-25-2014, 03:22 AM   #1
abstractmethod
Drives: Toyota Echo
Return fuel line.
Any one running a return fuel line with an aftermarket fuel rail and fuel pressure reg or is it not important... Would love to hear every ones opinions. TIA
abstractmethod is offline   Reply With Quote
Old 02-25-2014, 08:35 AM   #2
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
As the fuel is scarcely compressible, I see no advantage in moving the pressure regulation circuit from the tank to the engine.
Old 02-25-2014, 08:49 AM   #3
abstractmethod
Drives: Toyota Echo
Thanks for your reply. I'm more concerned about whether or not a return fuel line is necessary. If I don't have one will there be to much pressure in the fuel rail?
Old 02-25-2014, 08:52 AM   #4
When upgrading the fuel system for forced induction systems, a return fuel system upgrade allows you to install a 1:1 fuel pressure regulator. That allows you to have the fuel pressure increase by 1 PSI for 1 PSI of boost (to compensate for the plenum pressure).
For my supercharged Yaris, I modified a stock pressure regulator to increase the fuel system pressure to 6 PSI (which is the max boost for the S/C). I also increased one to 60 PSI for fnkngrv for his turbo setup.
Old 02-25-2014, 09:36 AM   #5
abstractmethod
Drives: Toyota Echo
Thanks mate
Old 02-25-2014, 02:12 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
what is your goal here?
Old 02-25-2014, 06:41 PM   #7
abstractmethod
Drives: Toyota Echo
My goal is to find out how necessary a return fuel line is for turbo application on a 1nz-fe..
Old 02-25-2014, 08:25 PM   #8
In a perfect system one with a 1:1 regulator would be used. For most typical applications (up to about 8 psi) it isn't essential, and very few of the boosted Yaris owners go that route. With the stock fuel pump one is not required, but with an upgraded fuel pump you may find that the manufacturer says that one is required. With a closed system there are spikes in pressure (that can shorten a pump's life) when the injectors close. With a return system those spikes are significantly reduced, since the regulator is close to the valves (injectors).
So, the question is how much boost are you intending? If you are going to stay in the 8 psi range, then you don't need to upgrade the fuse pump, but if you are going to go above about 12psi, then you will start to run into the limits of the stock pump.
Old 02-26-2014, 01:56 AM   #9
abstractmethod
Drives: Toyota Echo
Thank you very much. love how simply you can explain both situations.
I'm in the process of pulling down the block, and forged pistons and rods will be installed, ideally looking at 12-15 PSI for a daily driver.
Old 04-28-2014, 08:21 PM   #10
fnkngrv
fnkngrv's Avatar
Having a return style system will be crucial at that level of boost. Scott, GSD, and I determined that even with a modified stock pump the single line system will begin seeing issues at even just 9psi. This is with 1zz (240cc) injectors. You could do the lazy route and go with tC injectors (335cc) or the likes, but you will essentially being running pretty inefficient which will net you other problems or nowhere close to the potential you should see.
Old 04-28-2014, 09:37 PM   #11
This is with 1zz 9240cc) injectors.
Those are really big injectors.
Old 04-28-2014, 09:40 PM   #12
fnkngrv
fnkngrv's Avatar
lmao....fixed!
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 03:57 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Any body have good data on the Yaris fuel system? LtNoogie Performance Modifications 9 03-26-2009 08:01 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
