Old 02-27-2014, 08:05 AM   #1
Abdoudjaparov
Drives: Toyota Yaris 2001
change/remoe bulb in dashboard
We have run into a problem: We want to remove the light bulb for the indicator light for "engine failure". Is that possible?
We need the indicator to stop being lid and our mechanic tells us that there is nothing wrong with the car, so he can't make it stop!? I hope someone can help!
The car is from 2004.
Abdoudjaparov is offline   Reply With Quote
Old 02-27-2014, 08:34 AM   #2
Have you plugged a diagnostic scanner into the car to see what the code is that is making the check engine light be on. They don't turn on for no reason.
Old 02-27-2014, 09:02 AM   #3
Abdoudjaparov
Thanks for replying.
My mechanic has! And he says that there is nothing wrong...
Old 02-27-2014, 09:07 AM   #4
i second what CTScott says.
Have you tried getting a 2nd mechanic's opinion?
Old 02-27-2014, 09:55 AM   #5
Abdoudjaparov
No. We believe him...But say a light bulb has stopped working. Is it something you can change yourself? Or do you need a Toyota-dealer?
Old 02-27-2014, 10:49 AM   #6
The European ones have a bulb for the digital cluster and an LED for the analog cluster. The easiest way to disable the light either way is to snip the red wire with the yellow stripe on the instrument cluster connector.
The ECM has to ground that wire to make the light come on, so unless that ECM output has failed with a short to ground, the ECM is lighting it for a reason.
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 09:07 PM
Headlight bulb change....more to it than meets the eye... Yarflana DIY / Maintenance / Service 0 03-24-2013 08:56 PM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 09:22 AM
"L" shaped HID bulb big lo Cosmetic Modifications (Exterior/Interior) 6 01-29-2011 05:26 PM
