Old 03-08-2014, 07:51 AM   #1
scoundrel
Drives: 08 yaris
help needed (dash and taillight don't work)
Hi thanks in advance for any help sorry if this is in the wrong place im new to this stuff
Ok my friend has a 08 yaris 4door manual she loves the car but about 3days ago the dash and tail lights stopped working. It has a analog dash and standard stereo Ive checked fuses,taillight bulbs theres power at the fuses radio works just no dash lights or taillights
And no dimmer switch
Trying to save money if we can would prefer to fix it myself than pay someone
Any ideas
Again thanks for any help
scoundrel is offline   Reply With Quote
Old 03-08-2014, 02:14 PM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
You've checked both fuse boxes? There's one under the steering wheel and one in the engine bay.
MyzticZ3r0 is offline   Reply With Quote
Old 03-08-2014, 03:34 PM   #3
scoundrel
Drives: 08 yaris
Yeah i have checked both fuse boxes
Old 03-08-2014, 07:29 PM   #4
bairjo
Has there been any mods made to any electrical systems in the past. Also, no dimmer switch? The one on my Yaris is off to the left by my knee below the cup holder. Look there and try again. The tail lights may be a separate issue. Its worth a look...just fishin here.
Old 03-08-2014, 08:15 PM   #5
The Australian ones do not have a dimmer switch.
Check again the TAIL fuse in the fuse box that is under the bottom of the dash. Try simply replacing the fuse, as sometimes the fuses blow in such a way that the opening is not obvious when you look at the fuse.
Old 03-08-2014, 08:26 PM   #6
bairjo
Sorry about that...I didn't catch where he was at in the world.
Old 03-08-2014, 10:45 PM   #7
scoundrel
Drives: 08 yaris
No mods its standard everything
Old 03-09-2014, 08:04 AM   #8
Did you try replacing the TAIL fuse as I mentioned above?
Also, does you car have daytime running lights?
Old 03-10-2014, 09:01 PM   #9
scoundrel
Drives: 08 yaris
i have brought the fuses and will replace when i get the car back
I have attached a few pictures of the car so you can see what model it is
File Type: jpeg received_m_mid_1394438419086_ea9126f9a828229f08_1.jpeg (175.9 KB, 25 views)
