Old 04-13-2007, 02:52 PM   #1
R0ME0
Drives: '00 Toyota Celica GTS Turbo
17's widest possible?
Hey guys? I'm planning to get a set of 17's. I was planning to go 17x7.5 with a 42 offset. Just want to see if this will rub or even clear? I'm planning to go with a 205/40/17 tire. Will this combo clear or rub? Can I go any wider? Any insight on this would be much appreciated. Thanks!
R0ME0 is offline   Reply With Quote
Old 04-13-2007, 03:49 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I have 205/40/17 with 7.0 inch wide wheels. Don't go wider than this without wider tires as well. Get 215/40/17 if you want a 7.5 inch wide wheels. Also 7.5 is the widest you should go. 42 offset is good, so is 38 or 40mm.
Old 04-13-2007, 05:39 PM   #3
wagoneer
wagoneer's Avatar
Drives: 07 Liftback - Red
I read somewhere on the web in the last week that TRD recommends...
17x7 wheels
For the tire, I can't remember for sure but it was some combination of 205-215/40-45
Educate me gents!!! What does the offset do? Push the wheels tires out....or does in let the wheels "sit" in the wheel well?
I guess Im saying does the offset push the wheel to outside or the inside?
DRL removed
rear debadged
Tachometer installed
Mudguards installed
Rear Bumper Guard installed
FUTURE = Fog Lights, arm rest, RS spoiler, cruise, black 17" wheels
wagoneer is offline   Reply With Quote
Old 04-13-2007, 06:57 PM   #4
PetersRedYaris
More offset means your wheels will be pulled inward. Offset is the distance measured from the center of the wheel to the hub mounting surface.
I think 215/40/17 is recommended, but I have 205/40/17 and they work just fine. No rubbing.
Old 04-13-2007, 07:53 PM   #5
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I have 205 45 17 on 17 7'5 and no rub also...
so 205 is wider than 215?
-- Blen
Old 04-13-2007, 09:27 PM   #6
7.5" rims with 215 tires here, no rub. But, 215 looks a bit stretched, 225 or 235 may have been better.
Lookin to get 17's mattydface Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-02-2007 12:19 AM
16's or 17's riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 56 11-02-2006 08:44 PM
My new 17's! ;) Centurion2200 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 10-31-2006 01:08 AM
? for anyone with 17's or 18's plushDJ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-31-2006 11:12 AM
