Old 03-09-2014, 11:25 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Team Tiamat Racing's 2014 LSR Season Build (updated: 5-10-14)
For now this is just a placeholder. I will try my best to put things together to discuss all of my changes, plans, and upgrades with the high hopes of reaching 175mph in the standing mile and then whatever else I can get by the 1.5 mile.
Here is a teaser for now:
And even though not performance related:
Old 03-10-2014, 12:15 AM   #2
Jason@SportsCar
Valve cover is awesome.
Old 03-11-2014, 04:41 PM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Nice!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-28-2014, 12:20 PM   #4
Tid
Drives: 90 bmw 525i
love the cf valve cover
Tid is offline   Reply With Quote
Old 03-28-2014, 11:53 PM   #5
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
sweet motor man
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 03-29-2014, 12:36 AM   #6
fnkngrv
fnkngrv's Avatar
Originally Posted by scioncrew View Post
sweet motor man
Yeah, I am super stoked. You have no idea. I am hoping to continue the heritage of what great things it has done by getting it into the Guinness Book of World Records. I have submitted my application for this summer.
Old 03-29-2014, 01:28 AM   #7
scioncrew
scioncrew's Avatar
Drives: SCION tC
sweet so what is you setup?
Old 03-31-2014, 05:12 PM   #8
justjesus
justjesus's Avatar
Drives: 2008 Liftback
how much power you looking to make?
Old 03-31-2014, 05:57 PM   #9
fnkngrv
fnkngrv's Avatar
As much as we can. Hoping for 450+ on c12 or c16. Street will be much less aggressive as it will be on 91/93. Not doing water meth either.
From my m-o-b-i-l-e
Old 04-28-2014, 10:04 PM   #10
fnkngrv
fnkngrv's Avatar
Few teasers of the 2014 build:
New ID1000 injectors have arrived!
PTP Lava Rock Turbo Blanket!
BadLandz Electric Exhaust Cutout Kit!
Old 04-28-2014, 10:07 PM   #11
fnkngrv
fnkngrv's Avatar
The bulk of the work will be done over the next couple weeks. I have the car at the shop and we will begi work tomorrow. Pretty excited!
some basics:
- Engine install
- Turbo refresh
- Return Fuel System
- Battery Relocation
- Custom built oil catch can
- AEM UEGO refresh
- Upgrade to Boost Solenoid from manual controller
- Throttle Body work
Old 05-03-2014, 12:55 AM   #12
fnkngrv
fnkngrv's Avatar
Anyone up for some more pics?
Old 05-03-2014, 12:21 PM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I swear if there isn't a daily picture update, I will murder a kitten each day
-Derrick-
Old 05-03-2014, 02:38 PM   #14
fnkngrv
fnkngrv's Avatar
New Turbo:
Side by Side comparison of new EFR (Left) and old T28 (Right). Not really sure if the picture does enough justice on the difference, but it is a lot larger:
Throttle Body upgrade:
Tear down process for new new setup installation:
Old 05-03-2014, 02:42 PM   #15
fnkngrv
fnkngrv's Avatar
Recently both my UEGO O2 sensor and Autometer Oil Pressure Sending Unit (OPSU) died so I had to order new ones. Will be moving the OPSU to a T off the engine and removing the oil sandwish adapter that I have.
We have to fab a new downpipe due to the way the new turbo is designed. We suspected, but still a bummer. When we do it we will be getting rid of the second O2 bung for the rear factory sensor since it is not needed anymore.
Old 05-03-2014, 03:56 PM   #16
ilikerice
ilikerice's Avatar
When you do the OPSU, could you take pictures of where you are putting it and the hardware you are using.. I have been debating on weather or not I should get the Sandwich adapter or not, but wasn't sure where I could get another source of oil pressure.
Also, where are you getting a signal for your Water temp gauge? Are you using the signal from the OEM sensor to ECU? If so, what gauge are you using? If not, where did you install your Temp Sensor?
Sorry, I am in the process of doing my gauges and trying to find the cleanest and easiest way to do it.. searching for all my options.
thanks
-Derrick-
Old 05-03-2014, 04:05 PM   #17
fnkngrv
fnkngrv's Avatar
We can do that.
sent from my m-o-b-i-l-e
Old 05-03-2014, 08:17 PM   #18
fnkngrv
fnkngrv's Avatar
Any of the FI guys using a 3-3.5" thick/deep FMIC by chance? I am curious about clearances. Right now my FMIC is 2.5" thick/deep. I am wondering if anyone can confirm whether or not you can actually go as deep as 3.5". If so it opens up a lot more options since going with a taller version won't buy you much with the crashbar being in the way.
