Old 03-14-2014, 05:06 PM   #1
beeks81
Drives: engine only
Ignition wiring
I'm in the process of purchasing a 2007 Yaris 1.5L motor that I will not be putting in a Yaris. I'm trying to figure out the best way to wire it up and get it to run. If anyone has done it, I'd love to hear the details.
Option 1 go with stock electronics. TPS, ECM, Transponder ECU, ignition, and a wiring harness or 2.
Option 2 With an aftermarket ECU, I should be able to get away from the Transponder ECU, ignition switch and many non engine related wires. I'd still need stock wiring harness and TPS.
Option 3 other.
Someone locally is parting out a Yaris so I'd like to source as much as I need from him. Preferably all in one trip. Thanks in advance!
beeks81 is offline   Reply With Quote
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Cut Power Steering Wiring - Repair or Replace? mdyarisguy DIY / Maintenance / Service 1 07-28-2012 01:10 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
