Old 03-15-2014, 11:17 AM   #1
minisantos
Drives: toyota yaris t sport.
blitz supercharger issues.
finally got my blitz kit fitted up yesterday. got all the mechanical part sorted out.
my problem is though when its on boost its bogging down and not running properly. this is the diagram i've used to wire it up as its the only decent one i could find.
http://www.blitzpowerusa.com/techsup...scionxb-xa.pdf
is this the wrong diagram? the car is a 2003 uk yaris t sport running a blitz fuel controller. im abit stuck :( cheers.
minisantos is offline   Reply With Quote
Old 03-15-2014, 12:01 PM   #2
I think that one is incorrect based on the wire colors. Did you check it against what I PMed you on YCUK?
Old 03-15-2014, 12:04 PM   #3
minisantos
i need to find the ecu pinout diagram to see whats what on my car. i think it might be incorrect wiring. ive tried looking for my car's specific ecu diagrams to tell me what goes where but to no avail.
Old 03-15-2014, 12:30 PM   #4
What year is your T Sport?
And, can you snap a picture of your ECM connectors?
Old 03-15-2014, 12:37 PM   #5
minisantos
yep gimme a min :)
Old 03-15-2014, 12:46 PM   #6
minisantos
Old 03-15-2014, 01:09 PM   #7
Perfect. I will check to see if I have that one.
Old 03-15-2014, 01:11 PM   #8
minisantos
thanks bud. :)
Old 03-15-2014, 04:13 PM   #9
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Hope the tape is to protect the solder. Not a jab or a negative comment, just an observation.
07stlYaris is offline   Reply With Quote
Old 03-15-2014, 06:51 PM   #10
OK. Sorry for the delay - It's been a busy Saturday.
I am still looking for the T-Sport EWD. The Xb one in your link matches the connectors of your ECM, but when I check the Xb wiring diagram against your ECM wires are in the wrong places.
Besides the black/red and the brown being in the same place, did you find that the wires that you connected to matched the colors of the wires from the Xb guide, or did you just go by position?
Old 03-15-2014, 09:40 PM   #11
OK. Finally tracked it down.
Black wires: Ground - Any ECM brown Wire
Red: Ignition switched power - Black/red that you connected to
Yellow: Injector #2 - E3-2 Black/Yellow
Orange: Injector #1 - E3-1 black/orange
White: Injector #3 - E3-3 Black/White
Blue: Injector #4 - E3-4 Black/light blue
Light Green: VG (MAF Sensor) - E4-24 Pink
Green: To Blue activation wire for clutch
Old 03-15-2014, 10:47 PM   #12
TheBosna
Drives: bleh
Hi guys, I recently bought an 06 yaris that came with a blitz supercharger kit. One problem, it isn't spooling at all. The clutch light isn't on, the one on the controller, and I have it set to high right now. The car idles fine and everything, but the shifts seem longer than they should be. It's an automatic as well. Any help appreciated!
TheBosna is offline   Reply With Quote
Old 03-16-2014, 07:35 AM   #13
minisantos
all the wires are correct. its still doing it. im gonna go through all the sensors and check for air leaks in the system. ive also tightened the belt up.
Old 03-16-2014, 08:14 AM   #14
Was the gasket between the SC an the block new or used? That is a common leak point as well.
Old 03-16-2014, 09:34 AM   #15
minisantos
used, the boost pressure gauge is reading normal and it boosts to around 0.5 bar every time (on the gauge) . ive checked and cleaned the maf sensor and tightened it as well. it feels torquey at low throttle around 50% but if you give it full throttle it stutters.
Old 03-16-2014, 09:47 AM   #16
minisantos
i can also hear a whistling noise somewhere but can't pinpoint it lol
Old 03-16-2014, 10:29 AM   #17
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm cutting a fresh batch of gaskets this week. Not sure what shipping to the UK is, but I'm basically selling them at cost.
Old 03-16-2014, 10:33 AM   #18
biffy
Drives: ph2 yaris ts
Hes getting a set you made for me dude. Hope it sorts it out :-)
biffy is offline   Reply With Quote
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Blitz Supercharger w/ fixed pulley and supporting modds blacksandiegovitz Items for Sale by private party 25 10-11-2011 12:45 AM
Anyone using the Blitz Supercharger? revolution Forced Induction Forum 2 11-20-2010 05:57 PM
Blitz Supercharger and AEM Water Methanol Kit Morgan Items for Sale by private party 18 01-25-2010 10:54 PM
blitz supercharger!!! djgab101 Australia 4 11-20-2008 05:06 AM
