Old 03-21-2014, 11:43 AM   #1
sclary1999
Yargatti
Drives: 2010 Yaris Sedan
Unhappy Rear Camber on a 2010 Yaris Sedan!!!HELP
So I have a 2010 Sedan with 15x8 +25 rims with LoTek drop springs. I've rolled the fenders but when I hit a bump or have multiple people in the car it scrapes. I have Camber bolts on the front, but how do you camber the rear? I heard of shims but where do you put them exactly?
sclary1999 is offline   Reply With Quote
Old 03-21-2014, 03:04 PM   #2
They go between the brake drum and the axle hub.
Old 03-22-2014, 07:51 AM   #3
Flipper_1938
Flipper_1938's Avatar
Between the brake drum and the hub would make for a clown car ride (Wobble, wobble, wobble). The spacers go between the axle beam and the hub.
Old 03-22-2014, 12:21 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
See this thread to better understand it. But in the OP's case you'd either have hub spacers that are tapered - skinnier on the top, or some place washers on the bottom two bolts.
Old 03-25-2014, 12:58 PM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
realcamber.com makes -3 or -5 degree shims. He makes them for Scion XB/XD and Yaris/Prius. Just like Sugi said they install identically to the hub spacers in that link, that is the link I used to install mine as a guide. They are thinner on the top and thicker on the bottom. The Fab work is perfect and ive ran mine for about a 14 months or more without issue. The seller will include studs to use and provides even longer ones if you plan to run a hub spacer in addition. Remember these are fixed so chose your size wisely as they are very expensive for what you're getting. Also being that this is just a slash cut spacer you will be adding some negative effective offset so dont forget to account for that.
Old 04-02-2014, 11:13 PM   #6
MoneyT8
Drives: White Yaris Sedan
What are some good front/rear camber kits specifically front? All I see are camber kits that just come with bolts; is there more to it? Thanks.
MoneyT8 is offline   Reply With Quote
Old 04-04-2014, 07:31 AM   #7
1.5
Form>Function
1.5's Avatar
Up front you only use the camber bolts, top hole only on each side maxes out at 1.5-2. Both holes on each side maxes out around 3ish IIRC. Rear your only options are to cut and weld your axle or shims.
Old 04-26-2014, 11:30 AM   #8
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
Do those shims account for toe? I've been thinking about getting some but don't wanna kill my rear tires and have it get super sketchy in the rain.
DINOeggxo is offline   Reply With Quote
Old 04-26-2014, 01:59 PM   #9
1.5
Form>Function
1.5's Avatar
yes the dude is a great craftsman and the shims have a toe correct built in, ive never aligned my car with the shims but my tire wear is really impressive for -6 degrees so I know my toe isnt bad
Old 04-26-2014, 02:06 PM   #10
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
Daaaaamn 160$ haha...
Something else to save for
sasquatch is offline   Reply With Quote
Old 04-26-2014, 02:50 PM   #11
1.5
Form>Function
1.5's Avatar
yea lol for just some slash cut spacers but hey... gott pay to play lol
Old 04-27-2014, 11:46 PM   #12
FlushYaris
Drives: 07 yaris 3dr
Anywhere else to get them? He's all sold out..
FlushYaris is offline   Reply With Quote
Old 04-29-2014, 02:32 AM   #13
brianv
Drives: Toyota Yaris Sedan
Email him directly. He has them in stock.
brianv is offline   Reply With Quote
Old 03-19-2015, 03:21 PM   #14
Thebigwicks
Drives: 2008 lowered yaris on 17's
Anyone know how to get in contact with this guy? I NEED camber.
Thebigwicks is offline   Reply With Quote
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 12:06 AM
January 2010 Yaris Sales Thirty-Nine General Yaris / Vitz Discussion 8 02-03-2010 12:50 PM
