Old 03-21-2014, 10:42 PM   #1
vector9mm
Drives: blue 08 hb
a/c zoo odor and no cabin filter
As title states, my 08 Yaris has a smell and when I popped off the glove box, there was nothing over the fan but the white plastic. I opened plastic door and nothing behind it. I plan on installing a filter but do not see anything that could be causing smell. Anyone else missing a filter?
vector9mm is offline   Reply With Quote
Old 03-21-2014, 10:52 PM   #2
Do a search for AC smell and you will see a bunch of threads on this. The smell is coming from within the airbox (the large white plastic assembly that the fan assembly is attached to).
Old 03-22-2014, 07:51 AM   #3
BLH
Drives: 2007 Yaris Sedan
My 2007 shipped with no Cabin Filter installed.
Old 03-22-2014, 08:17 AM   #4
Prior to 2010, none came with the filter unless the dealer installed it. My 09 didn't have one, but fortunately I found YW just before I bought it, so on my way home from picking it up I grabbed a filter.
Old 03-22-2014, 05:44 PM   #5
You'd have it on a 06+ if you were in Canada. Canadian dealer would install it on 00-05 Echo if the heater core freezes.
Old 03-22-2014, 06:45 PM   #6
nookandcrannycar
On the opposite end of the spectrum, in the U.S. the Yaris (don't know about the ECHO) has always come standard with Air Conditioning. IIRC, that's not the case in Canada.
Old 03-24-2014, 12:03 AM   #7
vector9mm
Drives: blue 08 hb
I put in a filter and squirted some water/bleach up the A/c drain. Smell seems to be gone, not sure what did it but I'm happy. Thanks for the comments.
