Old 03-22-2014, 04:38 PM   #1
SignPirate
SignPirate's Avatar
Drives: 2007 Blue Yaris
Broke a sensor
I was changing the fan belt on my 07 yaris. I tried to unplug the wire from a sensor that screws in near the alternator and snapped off the plug. Not sure what type of sensor or how to get it out to replace it. Removed the alternator bracket for better access to the bolt unless the silver cover comes off the sensor it wont turn complete. Car seems to be running fine the check engine light is on. It looks like a head sensor? Any ideas?
SignPirate is offline   Reply With Quote
Old 03-22-2014, 05:29 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Does it look like the one in this link?
Or how about the pics in this link?
If it is, then it's the oil control valve sensor - a popular (and expensive) piece to snap off inadvertently.
Old 03-22-2014, 09:26 PM   #3
alanwagen
oil control valve
A lot of people have learned the hard way about this device. It is placed in a bad place for belt tightening.
Old 03-23-2014, 08:12 AM   #4
SignPirate
SignPirate's Avatar
Yep thats the sucker! Thank you. Now how do I get it out to replace? Took off the alt bracket to get to the small bolt but not sure how to remove the sensor,does it push in or screw out? Tried to screw it out but it only turns so much then hits that block above it. Thanks again guys
Old 03-23-2014, 08:38 AM   #5
It pulls out.
Old 03-23-2014, 09:46 AM   #6
That controls the VVT-i. You can run without it to no ill effects, but you'l have the Check Engine light on.
Old 03-23-2014, 10:04 AM   #7
SignPirate
SignPirate's Avatar
broke a sensor
I have run the car a little, definite check engine light. Thanks for your input. Will have to change it this week. Just googled it, not too bad, I want to thank all of you that responded, VERY HELPFUL!! This site still continues to be a GREAT resource for Yaris owners.Thank you.
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
2nd time O/2 sensor is needing replacing Astroman DIY / Maintenance / Service 8 01-29-2014 09:32 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
