Old 03-25-2014, 01:53 PM   #1
BWSMG
Drives: 2000 Yaris vitz 1.0 vvti
2000 Yaris oil type
Hi all ,
i have a 2000 yaris 1.0 vitz auto it has 105,000 miles , what type of oil would i get thanks a lot
BWSMG is offline   Reply With Quote
Old 03-25-2014, 02:14 PM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Castrol or Mobil 5w30 should be fine.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 03-25-2014, 02:20 PM   #3
BWSMG
Great , thank you
Old 03-25-2014, 02:48 PM   #4
Here's the Toyota oil chart for the 1.0L. It looks like they recommend heavier weight oil than 5W30, except for cold weather use:
Old 03-25-2014, 06:12 PM   #5
bronsin
bronsin's Avatar
Huh. What you know about that! 10w-30!
Old 03-28-2014, 09:09 AM   #6
BWSMG
Thanks guys :-)
Sent from my HSG1279 using Tapatalk
Old 03-29-2014, 12:04 AM   #7
frambach
Drives: 2008 Liftback
Not sure what kind of temps you see over in Dublin but, me personally, I wouldn't shy away from a 5W-30.
A 10W-30 and a 5W-30 are both 30 weight oils once they reach operating temperatures. So, there's no difference there.
However, as you can see, the "W" number is different between the two. The 5W is going to be ever so slightly thinner than the 10W when the temps drop.
All that being said, often times a 10W-30 will have a slightly better NOACK number (less likely to 'burn off') than it's 5W brethren. With that in mind, if you have a lot of miles, a 10W-30 may be a bit better fit for you.
Hopefully, armed with your new knowledge, you can now decide for yourself which weight oil you'd like to use ;)
frambach is offline   Reply With Quote
Old 03-30-2014, 06:56 PM   #8
BWSMG
Thank you frambach and everyone else for the advice i appreciate it :-)
Just bought a yaris hb...help with oil gabriel2012 DIY / Maintenance / Service 10 10-27-2010 05:49 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
