Old 03-27-2014, 06:42 AM   #1
ron3
Drives: 2012 yaris HB 5door LE auto.
tpms, older wheels question
I have a 2012 LE and want to install a set of 10 spoke wheels off a 2004-2007 Scion Not sure if the sensors will fit the scion wheels, my questions is If I don't install wheel sensors will the little yellow light be the only issue, or will I get a check engine code, also will not having the tire monitoring system working effect my warranty.
ron3 is offline   Reply With Quote
Old 03-27-2014, 07:34 AM   #2
The yellow light will be your only issue. The TPMS is not considered a fault for the engine related diagnostics.
If you go for service and the light is on and they see that you are running non-compliant rims, they may give you a hard time. In reality though they can only refuse warranty repair of anything directly effected by you running the rims.
Old 03-27-2014, 08:38 AM   #3
sex
sex's Avatar
Drives: 09 5DR
http://www.yarisworld.com/forums/sho...7&postcount=11
MR2 Spyder wheels on 08 Yaris question yotayaris08 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-26-2016 02:24 PM
OEM Wheels & TPMS ross sez Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-23-2010 03:21 PM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
