Old 03-28-2014, 05:32 PM   #1
Hershey
Suspension Cradle
The service department still has our car. Called today and was told that the suspension cradle had to be dropped a little more than normal in order to get to the strut (bolts?). Should we be concerned? Also they said that they would check the alignment and only do it if needed. Thanks
Old 03-28-2014, 06:16 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hey what !? What are they talking about ...drop cradle to get bolts for struts u are driving a yaris/ echo ...can't see why u would have to drop the cradle to remove struts .
Old 03-28-2014, 07:46 PM   #3
Sounds like they went to check the TSB for the A-Arm bolts and had one snap...
Old 03-28-2014, 08:37 PM   #4
Hershey
They already replaced the two bolts months ago. They said they were having a hard time getting some bolts loose due to corrosion and rust. The car will be there for 4 days as of tomorrow. They are replacing two struts, one rear shock on drivers side and a stabilizer bar link (?). We haven't been told if any of these have been installed, can't get any answers over the phone. Very frustrating.
Old 03-28-2014, 08:49 PM   #5
Sounds like the "B" team must be working on it.
Old 03-29-2014, 10:21 PM   #6
Hershey
Got the car back and it still crunches from the front and creaks from the back . It now seems be the passenger side rear shock . They replaced the drivers side rear shock due to leaking . Here's a list of what we think was installed for the front .
1.) 2 Absorber Assy, SH
2.) 2 Bearing , Strut MO
3.) 2 Support Sub-Assy.
4.) 2 Support , FR Suspe
5) 4 Nuts
6.) 2 Seat , FR Spring
7.) 2 Bush , Stabilizer ( Repair for Sway Bar Bracket )
These are printouts of specs for the new alignment on 3/28/14 and previous when first brought in 2/24/14 .
Old 03-29-2014, 10:41 PM   #7
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Seriously all the problems you have with vehicles.... Smdh
Sent from my C6902 using Xparent Skyblue Tapatalk 2
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-29-2014, 11:35 PM   #8
Hershey
No problem with the '11 Fit at 31,000 + miles (knock on engine block) . We started having issues with the 08 sedan at 20,000+ miles .
Old 03-31-2014, 01:42 PM   #9
Hershey
What would your next step be if your car still creaked / crunched from the front end and possibly the rear after all this work ?
Old 03-31-2014, 02:24 PM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Race Car!
-Derrick-
Old 03-31-2014, 05:22 PM   #11
nookandcrannycar
Race Car!
Old 03-31-2014, 05:33 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
if it is still under warranty document it and bring it to another dealership. And keeping doing that until you get it fixed.
Colin Chapman disciple
Old 03-31-2014, 06:51 PM   #13
Hershey
Didn't want to hear that .
Old 04-01-2014, 04:44 PM   #14
Hershey
Took the car for a drive on roads we usually travel and noticed when the steering wheel is level the car pulls to the left . Never had this since new . This is done on level roads . The car also feels like there's more resistance to rolling so have to apply the gas pedal more often . There was very little wind . Last , the crunches and creaks are more frequent and pronounced . May take it to a different shop for an alignment check , some only charge if needed .
Old 04-02-2014, 12:19 AM   #15
Hershey
We looked at the worksheet and alignment is not listed or charged to TOYOTA . Should be on it as a job performed , yes ? No ?
Old 04-02-2014, 06:22 AM   #16
Yes.
Old 04-05-2014, 11:52 AM   #17
Hershey
Got the car aligned yesterday , if interested , go here for the results . http://www.yarisworld.com/forums/showthread.php?t=50834 . Post # 8 .
Old 04-07-2014, 08:51 PM   #18
Hershey
What issues could be caused by pulling down the suspension cradle farther than normal ? Would that possibly make the car creak and crunch much more frequent and louder? Or could it be the struts weren't installed properly (bushings) or something else or a combination of all?
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Confort suspension for TS? shtou Yaris TS Talk 0 06-16-2011 01:27 AM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
