Old 04-03-2014, 12:20 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Is it ok to change Engine Oil after longer durations??? CT Scott please advice too
Hi,
The engine oil I use in my Toyota Belta is a synthetic oil (Shell Helix HX7) and its recommended mileage change interval is at 6,000 kms.
It's been about 8 months (Aug 2013) since my last oil change but I've only driven about 4,000 kms till todate.
I was told that its ok to change it at 5,000 kms keeping in mind the hot dusty climates here in our city/country here in Karachi, Pakistan.
Would appreciate your advice / suggestions please.
Thanks
Tyrone
tyrone_yaris is offline   Reply With Quote
Old 04-03-2014, 05:07 AM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I'd advise you to change the oil + filter. It seems like you only drive short distances; therefore, more contaminants. It's 5,000 miles or every six months. I'd be more worried about your filter as opposed to your oil - if the filter isn't doing it's job, the engine will suffer. You didn't specify if the filter had a recommended interval chance, but why be fugal when it comes to the engine?
MyzticZ3r0 is offline   Reply With Quote
Old 04-03-2014, 05:28 AM   #3
tyrone_yaris
Thanks for the reply. I guess you have a valid explanation.
The filter I use is a Thai make but am not sure how many kms.
Old 04-03-2014, 06:40 AM   #4
With oil changes I still run with what father drilled into me as a child - 3000 miles or 6 months, which ever comes first. I use synthetic oil, so I let myself go a bit longer to 4000 miles or about 9 months, but with 4 vehicles I can choose to drive (and the fact that I work from my home) I often hit the 6 month mark prior to the miles. My 2011 Tacoma only has 5000 miles on it and it has had three oil changes.
Old 04-03-2014, 07:14 AM   #5
tyrone_yaris
So CTScott, is it ok if i change at 9 months or 6,000 kms in my case?
Old 04-03-2014, 08:28 AM   #6
I would say yes, particularly since it sounds like you will typically hit the 9 months before the 6,000 km.
Old 04-03-2014, 08:43 AM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
You should change it now, especially if it is a very dusty climate. 6 months is really as long as you should go unless you use a full synthetic that states it can go longer.
Colin Chapman disciple
Old 04-04-2014, 12:57 AM   #8
tyrone_yaris
Thanks CTScott & why?
@Why?, when I mean dusty, its not like the desert dusty climate, but its quite smoky at times due to high pollution as compared to other cities. :)
Old 04-04-2014, 01:56 AM   #9
WingIt
Drives: 2005 NCP91 Vitz
I would be more worried about changing the air filter than the oil due to dusty conditions. 9 months/6000kms is excessive, I would say every 12 months or 10,000kms is just fine, many new cars have service intervals of 12,000kms and they run the same oil.
WingIt is offline   Reply With Quote
Old 04-04-2014, 02:22 AM   #10
tyrone_yaris
Thanks WingIT
Mine is a 2007 model and I make sure to change the air filter regularly.
Old 04-04-2014, 11:48 PM   #11
frambach
Drives: 2008 Liftback
I'm going to second a good air filter regimen.
Did you know the most important filter on your vehicle is your air filter? It's true.
A used oil analysis will really tell you what's going on inside your engine. I've done oil analysis and seen excessive silicon numbers in the oil. High silicon numbers lead to excessive wear metals (such as iron and aluminum) in the oil. As a general rule, when silicon numbers come back high, that means there's a problem with the air being supplied to the motor. Either there's a vacuum leak or the air filter itself isn't doing it's job.
As far as your oil goes, I don't see a problem at all with going the full 6k on it. It will be HIGHLY unlikely that your oil filter is at capacity unless you're using a cheap, junky, low-grade, cellulose oil filter. So, you can most likely rule out the oil filter being 'used up'.
I say all that to close with this; in your case mileage isn't the confining issue. Me personally, I wouldn't go over a 6 month interval on the oil without doing a used oil analysis based on your living conditions and driving habits.
frambach is offline   Reply With Quote
Old 04-04-2014, 11:52 PM   #12
frambach
CTScott, feel free to stop wasting resources, time, and money unless you really like changing oil.
Don't just take it from me...
http://www.edmunds.com/car-care/stop...anding-numbers
You could EASILY go to once a year oil changes with AMSOIL. Pick the time of the year that best for you and just say 'every June, I change my oil in all my cars' and done!
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change trevor1980 DIY / Maintenance / Service 3 02-05-2012 10:46 PM
My Oil Change Help Me, Please! JetfireK General Yaris / Vitz Discussion 6 01-09-2011 10:25 PM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
Dealership filled engine with too much oil... posaunemeister DIY / Maintenance / Service 17 10-18-2009 11:21 PM
