Old 04-16-2007, 01:35 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
How do you make keyless beep on unlock and unlocking the car.
How do you make keyless entry on the canadian yaris beep when unlock and locking the car? ANYONE!!! unfortunely its not on the manual..
Old 04-16-2007, 02:22 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I may be wrong, but I'm pretty sure the only yaris's that "Beep" are the ones in PR.... i was thinking of taking a look at the service manual (more so at the keyless entry section/pages) and see where I could tap in a "horn"...
anyone?
will work for parts
Old 04-17-2007, 01:06 AM   #3
jaspie
Lil White her name is ~
jaspie's Avatar
Drives: White YRX 5DR Hatchback 2006
anyone?
I'd like to do that too....let me know if anyone ends up doing it ^_^ ~
Jaspie ~
jaspie is offline   Reply With Quote
Old 04-17-2007, 02:45 AM   #4
I want to turn mine off! Just a stealth wink of the blinkers is good enough.
Old 04-17-2007, 08:10 AM   #5
punch
punch's Avatar
you can't we don't have this feature, and why would you want it to beep?
Old 04-17-2007, 08:37 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
it be nice that as your walking away for you car to know that it actually locked (i was in a parking lot and wasnt sure i locked my car, so I had to walk back so that I could see that the lights "flashed locked")
will work for parts
Old 04-17-2007, 09:34 AM   #7
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if you have the alarm then it will beep, otherwise you need to tap into the horn and do some wiring....
Old 04-17-2007, 09:53 AM   #8
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
Weird story here- I bought my Yaris brand new in October, and I always noticed the little "reset button" on my keyless entry key. Also, the panic button would not work. Well, when I was tinkering around the fuse box trying to install an amp, I crossed the wrong wires somewhere and my doors would not stay locked! They would automatically unlock by themselves right after I pressed the switch on the door (my keyless would not work at all). When I disconnected the wires for my amp to root out the prblem, everything went back to normal, AND found out the that "reset" button was actually a little red light that now worked and so does the panic button... go figure I screw something up and end up making something work! That was a first!
||)) (o) ||\|| is offline   Reply With Quote
