Old 04-18-2014, 01:28 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Electrical Gremlin
For some reason, every now and then, the radio cuts out when I brake or signal. Also the fuel/odometer gauge kind of flickers when the car is running.
Alternator output was around 13 volts, no noticeable out electrical issues. all though i'm pretty sure my exhaust is lose and keeps hitting the undercarriage on acceleration and deceleration.
Old 04-18-2014, 02:24 PM   #2
Do you have an OEM or aftermarket radio and have you done any under-dash wiring work?
And, 13V is low for alternator output. It should be in the 13.5 to 14.1 volt range with the engine running.
Old 04-18-2014, 05:04 PM   #3
Golddeenoh
Golddeenoh's Avatar
the only electrical things that are not EOM are the fog lights, grounding kit, and scan gauge.
Today on the way back from the doctor the car completely shut off electrically and stalled.
Old 04-18-2014, 05:07 PM   #4
OK. That really sounds like the alternator is bad or the battery has a bad cell and is pulling the alternator down.
Old 04-18-2014, 05:20 PM   #5
Golddeenoh
Golddeenoh's Avatar
alternator out put reading from the OBDII/Scangauge was 13.7, and the battery isn't very old It is only about a year old, but I guess I will test it, and make sure the connections are good.
It hadn't done anything like this since i had a short in the column from the fog light kit.
I did take the Battery out Wednesday to get to that tranny mount and tighten it up, makes me think that It might be making a poor connection at the battery some how.
Old 04-18-2014, 06:42 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Reminds me of a problem my dad's duster used to have. stupid insane electrical issues used to happen to him, the best one was one time on the highway the car just flat out stalled, the person in the passenger side opened the door and it started right back up. Turned out to be two stripped wires were crossing.
Just check all the wiring, it is probably something that will be obvious with a visual inspection.
Colin Chapman disciple
Old 04-18-2014, 07:13 PM   #7
13.6 is OK, so it very well may be the battery connection.
Old 04-18-2014, 08:47 PM   #8
nookandcrannycar
One of those things (re anyone) that could only really have happened .
07 Yaris loses electrical power intermittently. elcam84 DIY / Maintenance / Service 7 04-26-2014 08:15 PM
electrical problem 2007 5 door hatchback fford Canada 3 03-21-2013 02:02 PM
What electrical polisher do you use? tomato Wash, Wax, Detailing, Exterior Repairs 11 09-01-2009 12:34 PM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
