#1 |
![]() Drives: 08 4dr Hatchback Join Date: Aug 2010
How do I turn a "check engine" off?
It is ON since I fill the gas tank and did not screw the gas cap correctly. There might be a trick to turn it off but can't find on this site. Help please.
To reset it without a diagnostic tool, you can disconnect the battery for a couple of minutes.
#3 |
Thanks, I'll try it in few minutes as soon as it stops raining.
#4 |
Thanks CTScott; done!
#5 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
normally it take 40 warm up cycles or 80 Key cycles to clear a DTCs.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
| Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 17 | 08-16-2024 10:23 AM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| Projectors retrofit, black reflectors and dimmed front turn signals | my2sense | General Yaris / Vitz Discussion | 11 | 06-20-2012 11:39 AM |
| Are rear red turn signals planned for Yaris as well ? | 77W | General Yaris / Vitz Discussion | 38 | 02-22-2010 06:41 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
