Old 04-22-2014, 03:40 AM   #1
Kipker
Drives: Yaris P9 3dr Hatch '08
Will it fit? 7X16'' Offset +20 (car lowered 1.4/1.4)
I'm thinking about putting these BBS on my 08' Yaris 3dr hatch.
Rims: 7X16'' Offset +20 (car lowered 1.4/1.4)
They are mounted with 195/45-16 tires.
Will the setup fit or will it rub?
I have used the calculator on rimsntires.com, and came up with this result:
Suspension clearance:
100% clear (leaves even more room than OEM)
Fenders clearance:
Package 2 will stick out 30 mm (1.2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells clearance:
SPEEDOMETER:
When speedometer reads 60mph (96.6km/h) actual speed will be 57.9mph (93.2km/h): 3.5% slower.
Looking forward for some great answers.
File Type: jpg 1174623_10201883418868646_6185126150669162595_n.jpg (100.5 KB, 69 views)
Kipker is offline   Reply With Quote
Old 04-22-2014, 07:07 AM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You may have slight rubbing but its nothing a small amount of camber cant fix. I run -1.25 degrees up front and cannot notice any difference in tire wear. I would do it.
Old 04-22-2014, 09:06 AM   #3
Kipker
īThanks!
I also thought about adjusting the camber a bit but what about the rear tires will ther rub or are there more space in the rear.?
Old 04-22-2014, 10:03 AM   #4
1.5
Form>Function
1.5's Avatar
there is usually less space in the rear but 1.4" drop on our cars leaves a pretty large gap back there since we have a lot of rake stock. You probably will have a lot of gap so no rubbing unless on a huge bump or with passengers back there
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Who makes the best custom fit car cover for our car? YarisSedan General Yaris / Vitz Discussion 8 04-29-2009 11:13 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
