Old 04-23-2014, 06:19 AM   #1
Berni271
Drives: Toyota Yaris auto sedan
Starting problems after fuel filter replacement??
Since I've had my fuel filter replaced on my auto yaris sedan (2009) I've had problems starting the car - I would have to crank it for about ten seconds before it would start, it would shudder then start and it was very sluggish. The check engine light was on too. I took it back to the mechanic, they said the O-Ring didn't fit properly, fixed it and sent me on my way. It all worked perfect until I filled up with fuel, and now I have the same problem again. Any ideas what it could be? I can't afford to take it back to the mechanic :(
Thanks
Berni271 is offline   Reply With Quote
Old 04-23-2014, 06:43 AM   #2
The mechanic who did the work should be responsible for rectifying the issue. It sounds like he did not properly reassemble the fuel sender assembly and it is leaking off the pressure.
Old 04-23-2014, 06:46 AM   #3
Berni271
Cheers for that, hoping it's a quick fix! :)
fuel filter, starting, yaris sedan 2009
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
HELP: Swings but does not start after fuel filter replaced REV 2 11 DIY / Maintenance / Service 12 08-19-2013 01:38 PM
Fuel Filter caveatipse DIY / Maintenance / Service 27 12-28-2012 09:45 PM
fuel filter ias205 General Yaris / Vitz Discussion 15 05-14-2007 11:02 AM
