Old 04-23-2014, 11:48 AM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Question Strut Bearings
How long do Strut Bearing normal last on the front of the car?
Car has 52k Miles on it, been lowered since original new purchase.
Mine are making some really bad noise and they are binding. the bind on turns and can be heard when you approach the steering stops in both direction and when the load shift on the vehicle (initial braking and acceleration).
Old 04-23-2014, 11:55 AM   #2
I have run struts for over 100K miles without having the bearings fail. I think them failing prematurely (i.e. before the struts are due for replacing) would be due to them taking hard hits with the suspension bottoming out.
Old 04-23-2014, 12:34 PM   #3
Golddeenoh
Golddeenoh's Avatar
I figured my 55mph on 10mph corners would have some effect, but the roads are rough around here and that does make sense.
Old 04-23-2014, 12:47 PM   #4
You're not the first to have them fail either. I sold a set off the Yaris that I parted out to someone else who had them fail prematurely.
Old 04-23-2014, 08:21 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I had one fail last year, but I believe it was related to a defective spring.
Old 04-25-2014, 03:15 AM   #6
mr_miles
Drives: 2013 Yaris
Nonsense. You speak silly words. Our cars are meant to do that.
Old 04-28-2014, 07:59 AM   #7
I'm on my 3rd set on my echo. 150K km
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Tanabe front strut tower brace or Ultra Racing strut tower brace? sternz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-14-2010 06:14 PM
Rear strut tower bar problem mrbond Performance Modifications 25 09-22-2009 02:32 AM
Strut bar - To preload or not to preload that is the question YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-02-2009 09:38 PM
