Old 04-24-2014, 09:41 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Stock Piston and Rod details
So I have had a few questions as of late about the stock parts since I have had a couple motors apart now.
There are no bushings and neither the pistons nor rods are coated.
sent from my m-o-b-i-l-e
Old 04-24-2014, 10:04 PM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Nice pictures, that piston is a bit smaller then i thought lol. I have a few questions if you don't mind, 1: Did you ever have a ring land fail or melt a hole or other destruction of a stock piston in any of your engines? 2: Does the stock rod have a oil feed to the wrist pin?
LTHatch is offline   Reply With Quote
Old 04-24-2014, 10:08 PM   #3
fnkngrv
fnkngrv's Avatar
No problem with pistons. Blew apart a rod into about a half dozen pieces.
Oil feed:
Old 04-24-2014, 10:39 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Thanks for the info, gives me lots of insight. The stock piston design is way better than I was expecting so I guess I'l sticking with those. Wish the rod was floating design, but its still good.
Old 04-24-2014, 10:45 PM   #5
fnkngrv
fnkngrv's Avatar
Cleaned piston:
Oil hole crank side:
Old 04-24-2014, 11:44 PM   #6
fnkngrv
fnkngrv's Avatar
Not a problem at all. Glad to help.
Limits of stock 1nzfe found once and for all. pimp my yaris Forced Induction Forum 166 11-24-2012 10:30 AM
