#1 |
![]() Drives: Toyota Yaris Join Date: Apr 2014
Questions about replacing shocks and struts on a 2007 3 door Yaris
Hey,
This is Cassie. I am new to this site and to Houston (Texas). I own a Toyota Yaris, 3 door, 2007 model with approximately 80,000 miles. I believe I need to replace the shocks and struts on my vehicle and need your advice. I went to the nearby Toyota service center and they quoted me ~$1300 for just the front shocks and struts and alignment. In comparison, a local shop, whom my friend has used, and has average reviews of, quoted ~1000 for all four wheels. I noticed that most of the cost is for labor. How much should such a service cost? And is it something I should go to the Toyota service center for? Or is any reputed mechanic/service center good? Any advice on how to approach is welcome...I am an auto amateur. Also...any recommendations for any service center/mechanic in Houston is welcome...preferably near Spring or Westheimer/Beltway thanks Best, Cassie |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
a friend's garage quoted me 580$ for 4 KYB shocks. You should be able to change all that in about 1.5hours, so probably you'd get quoted 2hrs of labour + alignement. So around 800-1000$ depending where you go. OEM parts cost more too.
#3 |
Here are some pictures of a tire. Does this seem in line with what one would expect due to worn out shocks/struts?
![]() ![]() Thanks, Cassie :) |
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
Do you drive mostly within city limits and snag a lot of those just about unavoidable potholes (understandable) ?
I don't drive on surface streets within city limits that often, and I'm still on my first OEM shocks and struts. I think Ripley's will give you an honest opinion. I've gone to the one on Rayford Rd near I-45 in the Montgomery County part of Spring. They also have another location (the original) on the NW corner of FM 1960 and Kuykendahl. |
#5 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
looks like it has tons of positive camber, to make that kind of tire wear.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#6 |
2.5 hrs is right plus parts but u can save by doing rear at home just have them do front and alignment ..
Sent from my XT1032 using Tapatalk |
#7 |
Can you take pictures of the full tread width? It may be that you only need new tires and an alignment
#8 |
#9 |
If your shocks/strusts were bad, it would have a wacky wear on the thread.. like the circled one.
| Tokico Blue Struts and XD Shocks | rexseesyou | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 03-18-2014 06:46 PM |
| For Sale: TRD Sportivo Springs, Struts and Shocks | CTScott | Items for Sale by private party | 7 | 01-20-2014 06:59 PM |
| FS BNIB Tokico Struts and Shocks | nisyota | Items for Sale by private party | 12 | 12-29-2010 02:35 AM |
| New OEM KYB '07 Liftback Springs & Shocks (Struts) | GuySmily | Items for Sale by private party | 7 | 07-25-2010 05:02 PM |
| Shocks & Struts | devinlamothe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 03-31-2010 08:20 PM |
