Old 05-02-2014, 09:01 AM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Valves Tapping
My '09 Yaris has 114k miles on it and the valves seem to be gotten louder over the last 10k or so miles. I did 86 the stupid cover years ago so its not that. I did just recently put in a lighter steel flywheel when I replaced the clutch. It does sound fine when driving and no lights are on. I'm just a tad worried about the knocking during idle, especially on cold start up. And I've been running Royal Purple Synthetic since I got the car 2 1/2 years and 68k miles ago.
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 05-02-2014, 11:49 AM   #2
bronsin
bronsin's Avatar
Check the valve clearances. If you did the clutch and flywheel yourself this shouldn't be difficult. If they are really loose there's your problem. You have to record the clearances and remove the camshafts to adjust however which is more involved.
However, in my experience with (motorcycle) engines with this system, the clearances usually get smaller not larger. (the valve seats wear) Which can lead to burnt valves! So you REALLY want to do the adjustment if the clearance is out of tolerance on the low side.
Old 05-02-2014, 12:14 PM   #3
detroiter
detroiter's Avatar
I thought the same before and it turned out that it was just the injectors. From my understanding of most toyota car enthusiasts I've talked to, toyotas tend to always have loud injectors that sound like ticking/tapping even when new.
You very well could be right on your actual valves, I'm just trying to help out.
Old 05-02-2014, 01:43 PM   #4
BobTheYaris
Injectors sound possible. Most of the miles are highway so Im not sure they'd be out.
Old 05-02-2014, 08:59 PM   #5
bronsin
bronsin's Avatar
Now that Detroiter mentions it Ive also heard injectors can make this noise.
But CHECKING the clearances is pretty easy, its free if you do it yourself, and if theyre good next step: injectors.
Old 05-04-2014, 11:37 AM   #6
barefoot_bajan
barefoot_bajan's Avatar
Drives: 02 vitz rs
no walkthrough?
so many pedestrians..... so little time
barefoot_bajan is offline   Reply With Quote
OCV valves yaris9876 DIY / Maintenance / Service 6 01-14-2014 04:16 PM
Tapping engine while in drive or reverse, at idle only? SWICKENSJR DIY / Maintenance / Service 16 12-04-2010 11:18 AM
Valve's broken. N3misiS DIY / Maintenance / Service 17 11-15-2010 04:35 AM
Tapping into OEM horn for alarm economatic DIY / Maintenance / Service 17 10-19-2009 10:07 PM
uhoh....valve tapping already???? iwantayarisnyc General Yaris / Vitz Discussion 13 12-11-2008 12:56 PM
