Old 05-02-2014, 04:16 PM   #1
Stenis
Drives: Hybride
back light
Hello
Do anyone know if it's the same typ of electrical connector of this two backlight? the first one is with led and the second the ordinary backlight.
Both of them are toyota original.
I have the ordinary backlight, but thinking of swiching to the backlight with led.
Stenis is offline   Reply With Quote
Old 05-06-2014, 07:19 AM   #2
Punishdln
Drives: Yaris 3 2011
I'm thinking about this . You should ask to toyota
Punishdln is offline   Reply With Quote
Old 05-10-2014, 03:01 AM   #3
falconrocks19
BLAH.
falconrocks19's Avatar
Drives: 2012 Toyota Yaris
Wow! It's bootyfull! Find out and let us know!!
falconrocks19 is offline   Reply With Quote
Old 05-12-2014, 02:44 PM   #4
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
Very interesting. Please keep us updated. This looks to be a fun modification.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 05-24-2014, 01:29 AM   #5
Stenis
Drives: Hybride
Anybody know how to remove the taillight?
My taillight seems to be stuck even if a try quite hard to remove the taillight.
ideas? how I shall do?
Old 05-24-2014, 06:55 AM   #6
According to the service manual, after you remove the two mounting nuts you need to release to two upper clips and the lower pin to remove the taillight. It also says that you need to remove the rear bumper to do so.
Old 09-24-2014, 12:26 PM   #7
Mazabala
Drives: Yaris 2012
How this mod. come out?
I have been wanting to change my tail lights so bad.
Mazabala is offline   Reply With Quote
Old 10-07-2014, 05:12 PM   #8
AlyM
Drives: Yaris 2004
Mines came with the LED lights... But I replaced the number plate lights for LED ones 👍
AlyM is offline   Reply With Quote
Old 10-07-2014, 05:13 PM   #9
ucsmfu
Drives: yaris le
where can u buy these tails ?
thanks
ucsmfu is offline   Reply With Quote
Old 10-07-2014, 05:37 PM   #10
AlyM
Drives: Yaris 2004
I've seen them on eBay, but here in the UK most year 14 Yaris if not all have them as standard..
Old 10-07-2014, 09:22 PM   #11
ucsmfu
Drives: yaris le
I noticed you have a reverse camera on yours. Is there an oem parts number for that ?
thanks
Old 10-08-2014, 01:33 AM   #12
AlyM
Drives: Yaris 2004
thanks
No idea... But I'll check on Monday for you!
Old 10-08-2014, 02:23 AM   #13
ucsmfu
Drives: yaris le
thanks
Old 10-08-2014, 01:25 PM   #14
marspike
marspike's Avatar
Drives: Yaris 2014, Y. HSD 2013
No you need a special pin connector to be work Leds taillight, reverse and turn signal are the sames.
You pay each wire 25-30€ approximate 35-40 US bucks.
marspike is offline   Reply With Quote
battery light stays on but running fine galactus Mid-Atlantic 13 08-15-2013 09:50 AM
HELP! Interior Light Color Change Seedo broke chilly79 DIY / Maintenance / Service 9 10-25-2010 09:20 AM
'09 Fog light replacement Mavix Cosmetic Modifications (Exterior/Interior) 5 10-07-2009 03:21 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
