Old 05-06-2014, 06:58 PM   #1
detroiter
detroiter's Avatar
Best place to jack up?
Going to switch out the struts/shocks but don't know where to jack the car at. I have access to one jack and two jackstands. For some reason the rear jackpoint under the rear bumper has caved in, so I don't think I can use it.
Any suggestions how to pull off this project?
Old 05-06-2014, 07:44 PM   #2
For the rear, instead of using the damaged "center" point you can simply jack one side at the pinch seam and stick a jack stand in and then repeat on the other side.
Old 05-07-2014, 10:01 AM   #3
detroiter
detroiter's Avatar
Thanks for the suggestion, that's what I was thinking of doing but I wasn't sure it was a good spot to do it or not. Looks like the project is off again since today turned out to be a rainer.
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
Where to place jack on front end? 09box DIY / Maintenance / Service 4 05-02-2010 06:11 AM
ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 ROCKLAND TOYOTA NY / NJ/ CT / PA 198 08-05-2009 01:04 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
