Old 05-13-2014, 03:14 AM   #1
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
10mm or 15mm wheel spacers for front wheels?
sitting on stock steelies with 175/65/15 tires
lowered on s-techs
-2.75* camber
will 15mm be too much and cause rubbing, or should i play it safe and get 10mm spacers instead?
anyone have any pics with 15mm spacers up front?
thanks in advance everyone!
b20vteg is offline   Reply With Quote
Old 05-13-2014, 04:42 AM   #2
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Never done front... in my opinion I will never do it, because the front wheels get all the beating (steering & throttle / braking). but thats my feeling.
Also... whatever you do, don't take system 4 spacers, because everything lower than 20mm will push your wheels outside (the bolts are sticking out of the spacer).
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 06-05-2014, 09:22 AM   #3
Lars
Yaris beginner
Drives: Yaris XP9F
I have 10 mm in the front with everything else stock. I'll post a picture shortly.
Lars is offline   Reply With Quote
Old 06-05-2014, 09:23 AM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I run 5mm up front, I am kind of in the same boat as G-Ammo, I just feel uncomfortable having to put new studs in and ride around on those up front
Old 06-05-2014, 11:08 AM   #5
Lars
Yaris beginner
Drives: Yaris XP9F
Well... 5 mm spacers (the ones I've seen) are not hub centric, the 10 mils are, so the spacer should take most of the beating, not the studs...
But, I would agree, if you're going to be driving very aggressively, and have the budget for it, you'd be better off buying new wheels with the offset you are looking for.
For now I'm happy with the 10's! And the difference in handling is noticeable, not just good looking :)
Picture attached. That's 15 in the back, 10 in the front, all else stock (for now).
Ichiba / H&R Wheel spacers? kid chino Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-05-2010 01:29 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Wheel balancing Alumimum wheels: CAUTION NEWBY tomjasz Cosmetic Modifications (Exterior/Interior) 3 08-20-2006 03:50 PM
