Old 05-17-2014, 02:24 PM   #1
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Inside wheel lifts.. anyway to reduce?
Under fairly aggressive cornering the inside front wheel lifts and spins..
Car currently has tokico blues, tein springs and a rear sway bar.
What can be done to reduce this happening? Or is it just me going too fast..?
SKurj is offline   Reply With Quote
Old 05-17-2014, 04:05 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
stiffer suspension
Old 05-17-2014, 04:26 PM   #3
LSD.
Old 05-17-2014, 04:38 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Slow down lol
Sent from my XT1032 using Tapatalk
Old 06-05-2014, 09:19 AM   #5
Lars
Yaris beginner
Drives: Yaris XP9F
I don't agree with the stiffer suspension...
Inner wheels get off the ground all the time in racing with the "best" (nice and stiff?) suspensions...
Actually, I think it's the opposite... your wheels get off the ground more often when your suspension is too stiff... so when you hit a bump your wheel flies off the ground...
Anywayzz, I agree with IllusionX... best solution is an LSD, so that you don't lose so much torque in the wheel that stays on the ground.
Lars is offline   Reply With Quote
Old 06-05-2014, 09:22 AM   #6
1.5
Form>Function
1.5's Avatar
very true ^^
Old 06-05-2014, 11:00 AM   #7
a bit of oversteering will also help your inner front wheel to stay on the ground too.. i think.
The only reason is that you are losing your rear end, and you have to counter steer/accelerate to keep yourself on track before the G force lifts your car on aggressive cornering.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
Resistance/rubbing On Wheel During Sharp Turns? tasha Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-11-2010 04:25 PM
