Old 05-22-2014, 03:50 PM   #1
Silverkarn
Drives: 2008 Toyota Yaris 2D
Easiest way to fix paint chips?
I have a bottle of 8T1 Bayou Blue + clearcoat on the way in the mail.
I've done some reading, and i don't know if i'm real comfortable using sandpaper on my car, even if it is 2000 grit
I'm starting to think i wouldn't mind "little bulges" in the paint, as long as the metal is covered.
I have 2 chips on the side of my car, both just a bit smaller than the width of a pencil eraser. Both chips have a small pinhead size spot of rust in the center. Also on the edge of the door there is an are about 2 inches long, and 2-3 mm wide where the paint has come off and it has visible brown rust along the whole thing.
Is there an easy way of going about this? How do i remove that rust? I cant find a "fiberglass pen" at any auto parts store.
Silverkarn is offline   Reply With Quote
Old 05-22-2014, 09:54 PM   #2
nortonfb
Drives: 2007
This what I have done. Use at your own risk.
Alcohol to clean the inside of the chip.
Tape the paint to protect it and a little at a time, let it dry.
For the rust: Rust remover like rustoleom, use a saturated tooth pick &
multiple applications. Don't let it run.
Use a match stem. Dab the chip, dry with a hair dryer. Keep building up
coats. The last fill with paint should be slightly above the surface.
A quick swipe with match book cover will not knock it down.
Not perfect but it will blend in and stop the rust.
Steve
nortonfb is offline   Reply With Quote
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
FIX car PAINT AND GLASS EVEN INSIDE THE CAR AND HOUSE FOR A BUCK.....READ jay cobbs DIY / Maintenance / Service 5 01-19-2013 01:57 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Best way to fix rock chips and small key scratches? Shinare Wash, Wax, Detailing, Exterior Repairs 2 11-05-2010 07:43 AM
Got some chips on the Yaris from my 100 miles commute, any suggestions for a fix? firebird1999us DIY / Maintenance / Service 6 04-26-2009 01:53 AM
