Old 05-26-2014, 11:06 AM   #1
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
turbocharging a yaris...a theoretical question
I have read a few turbo-ing a car guides, saw a few youtube videos and all share the same thing. they all say you should get some kinda new aftermarket ECU, since the air entering will be different and the engine will run lean.
My question is, cant the MAF sensor detect the change in air flow? Cant the stock ECU adjust the fuel injected accordingly?
tamrat is offline   Reply With Quote
Old 05-26-2014, 11:26 AM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
It does not have enough range to cover boost. They map the engine to handle all intended conditions. They are not going to waste time developing tunes to handle boost for a handful of enthusiasts
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-26-2014, 11:26 AM   #3
malibuguy
Obsessed with 1.5L
That being said...my tercel handled 3.5lbs of boost perfectly with no tuning.
-96 Tercel 4dr
Old 05-26-2014, 02:14 PM   #4
tamrat
so an aftermarket ECU is a must?
does the Blitz Supercharger come with an ECU? I have read that it makes about 7psi of boost.
The Surf is still here.... But now there is a Yaris next to it!
Old 05-26-2014, 02:20 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
Moved to the forced induction forum.
Old 05-26-2014, 02:36 PM   #6
the blitz kit sold at MicroImage is sold as a complete kit, including Fuel controller, on/off switch, all hardware, instructions
http://shop.microimageonline.com/BLI...BLITZ-SC-Y.htm
Old 05-26-2014, 05:06 PM   #7
mario98c
mario98c's Avatar
You need a return style fuel system and a 1:1 fuel pressure regulator. That will help you a lot when the boost comes on.
Old 05-27-2014, 06:32 AM   #8
tamrat
so I downloaded the online install guide and the thing has about 40 components and there is no ECU....the only electrical thing I can see is a relay, some harnesses and connectors. if that thing is adding 7PSI with out any chip tuning, wouldn't it be possible to achieve this with a turbo for a far less price?
Old 05-27-2014, 06:58 AM   #9
Rigaud
Drives: 2009 Yaris
Turbo's are not cheap either and a lot of DIY fabrication. Plus on these engines, I wouldn't go more then 6psi boost with the stock internals if you want to drive daily and last. 8psi max on stock engine and even then the life span is shortened. Theirs a sticky section here about it I believe.
Unless I'm wrong, someone can correct me.
Personally, I wouldn't boost mine unless I built up an engine for it. With the amount to invest in a good Turbo, mind as well go all the way and do it right.
My 2cents
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 05-27-2014, 07:53 AM   #10
The Blitz kit includes a Blitz Fuel Controller, which is a very small piggy-back fuel controller. It is designed to be used with bone-stock Yaris and is not adjustable, so if one is running an intake, other than stock, additional fuel must be added beyond what the Blitz controller adds. This is most easily done by upgrading the injectors to a set from a 1.8L 1ZZ-FE.
Just bought my Yaris - drink holder question. ceily General Yaris / Vitz Discussion 24 06-21-2009 10:10 PM
