Old 04-18-2007, 04:08 PM   #1
JadeSeaYaris
Drives: Jade sea 07 yaris sedan
I want DRL
I been looking to see where i can get the little box that plugs in to your car(inside the dashboard) that allows you to have daytime running lights.
JadeSeaYaris is offline   Reply With Quote
Old 04-18-2007, 10:48 PM   #2
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Use the parking lights,the yellow ones in the front,alot of people have switched these out for high output white LEDs.
eco is offline   Reply With Quote
Old 04-19-2007, 12:24 AM   #3
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Jade Sea Yaris- I also wanted DRL'S but couldn't find an OEM module, as it's not a simple plug and play. I do have a module from webelectrics that lights up my amber turn signals about about 3x brighter than the parking lights for a unique (at least for a Yaris) look.
http://www.webelectricproducts.com/
I also have the brakelight pulser, which is another good product.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 04-23-2007, 01:44 PM   #4
wagoneer
wagoneer's Avatar
Drives: 07 Liftback - Red
turning the headlight switch to the "parking light" position, turns on the headlights at low power (DRL).
I removed my DRL module from my LB because I want to be in control. Putting the switch in said position is the same look as with DRL enabled.
DRL removed
rear debadged
Tachometer installed
Mudguards installed
Rear Bumper Guard installed
FUTURE = Fog Lights, arm rest, RS spoiler, cruise, black 17" wheels
wagoneer is offline   Reply With Quote
- DISABLED DayTime Running Lights How To- 2007 Yaris! - Chris07LB DIY / Maintenance / Service 266 09-04-2017 03:34 AM
HID's and Daytime Running Lights rage2 Cosmetic Modifications (Exterior/Interior) 17 04-13-2007 02:10 PM
DRL enabled with HIDs... sort of... Galavoxx Cosmetic Modifications (Exterior/Interior) 0 03-28-2007 08:26 PM
Using parking light as DRL? GabL DIY / Maintenance / Service 6 11-11-2006 09:31 AM
NO DRL ???? argylesocks DIY / Maintenance / Service 8 08-12-2006 08:24 PM
