Old 06-03-2014, 01:00 AM   #1
ZAKU
Drives: 2007 Yaris RS
C160 Helical LSD in a C50 transmission?
I have a 2007 Yaris with the C50 transmission, and I have found someone that is selling a C160 trans from an AE111 Corolla that might have the factory helical LSD.
As far as I can tell the C50 and C160 diffs should be interchangeable, am I correct?
Are there any other issues I might run into if I try to install the C160 diff in my C50 trans?
Just looking for some clarification before I buy anything, thanks in advance.
ZAKU is offline   Reply With Quote
Old 06-03-2014, 08:41 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I think BluevitzRS is the resident expert on the C160 -> C50 transplant, but I'll take a whack at it. It's definitely an 8-bolt differential, which is a good start, but without having one in hand to compare measurements, I can't confirm any further.
Old 06-03-2014, 09:32 AM   #3
For the TRD LSD, the AE111 and the NCP91 use the same LSD (41301-AW004), so I would think it would work.
Old 06-03-2014, 09:37 AM   #4
Rigaud
Drives: 2009 Yaris
Here!!
http://www.yarisworld.com/forums/showthread.php?t=26728
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 06-18-2014, 08:21 AM   #5
As long as the the diff in the C50 is 8 bolt, it should fit. You just need to swap the gear bolted to it and the speed drive gear if it's any different.
Old 04-11-2024, 10:09 AM   #6
YarisLurker
Easiest way to get LSD in your Yaris
What is the easiest way to gain limited slip Transmission in your 2008
Yaris?
I define easiest by taking out the current stock transmission, and installing a transmission that has LSD in it. What is there a transmission offered in the United States C 50 that had LSD already installed in it?
If so, what model cars were they in and what part number would you look for to identify it?
YarisLurker is offline   Reply With Quote
Old 04-12-2024, 02:37 AM   #7
remcafee
i installed a quaife qdf15e lsd in my c50, it is actually fairly straight forward to do once you understand how it all comes apart, as far as im aware, there are no factory c50, c52, c56 yaris transmissions that come with an lsd already from factory, always has been an add on
Old 04-12-2024, 10:29 AM   #8
YarisLurker
I wondered if you recommend a particular place to buy a 15 E ?
Old 04-12-2024, 04:34 PM   #9
remcafee
i bought mine from quaife website, took about a couple months to get, but couldnt be happier, youre in tuscon right? if you ever need help let me know i can show you how to install it and i made a tool for bearing preload adjustment
Old 04-13-2024, 01:07 AM   #10
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
There are C52s and C56s that are factory LSD in other models and markets.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
Lsd for C51 gearbox thefalls Forced Induction Forum 19 08-16-2012 08:51 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
TRD Helical LSD kngrsll Items for Sale by private party 18 04-27-2009 11:16 AM
