Old 06-07-2014, 10:05 PM   #1
exileddeus
exileddeus's Avatar
Drives: '10 Yaris HB
beams 3sge fs
[IMG][/IMG]
[[IMG][/IMG]
Hey all, figured I would post this here too. One of you all may be interested in this. I have a 5th generation BEAMS 3S-GE blacktop for sale. This one was bought about 3years ago for a project AE86 that didn't pan out. It is a low mileage motor, and it shows. The bottom end looks good, as does the valve train and clutch. It has a new water pump and oil pump on it from a 5S camry. This allows the motor to run a smaller camry oil pan which is a little more swapfriendly than the OE hammer head pan. Both a moddified camry pan and the OE pan will be included. The OE pan needs some love( it was cut for notching, just needs to be weilded back). This motor will need an ecu, wiring harness, timing belt and alternator. All the OE parts I have are in good shape and included as well. RWD 6- speed manual trans is included as well.
Anyway, sorry for the poor quality of pics, feel free to ask any questions about the motor if interested. NOT wanting to ship this as it would have to be freight and complicated. Located near atlanta. Asking $1000
exileddeus is offline   Reply With Quote
Old 06-07-2014, 11:59 PM   #2
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
too cool
B2FiNiTY is offline   Reply With Quote
Old 06-08-2014, 09:37 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Put it in the yaris now
Old 06-08-2014, 12:35 PM   #4
exileddeus
exileddeus's Avatar
Lol that would be a lot of work......if it even fits. Definitely wouldn't pass emissions :/ still though 205na hp on hand would be nice.
Old 06-09-2014, 06:56 AM   #5
1.5
Form>Function
1.5's Avatar
lol because racecar
Old 06-09-2014, 03:54 PM   #6
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
My brother has one of these in his MR2 import :D those engines are SICK...!! Going to buy a MR2 too when I can afford it.. probably a Beams too :)
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 06-09-2014, 04:24 PM   #7
Brett!
Drives: 2010 3D base
what is a good application for this engine (aside from ae86/camry/mr2) - would it be a fun engine for a geo metro or yaris? :D
Brett! is offline   Reply With Quote
Old 06-09-2014, 04:38 PM   #8
exileddeus
exileddeus's Avatar
Well, technically this is a rwd motor (from an altezza rs200) but the fwd trans from the mr2/ camry should bolt up. Its a tall motor, idk if it would fit into a yaris engine bay. Axles would probably the hardest part outside of fitment
Old 06-09-2014, 06:23 PM   #9
Brett!
would I be a cool guy if I put it in an old single cab toyota tacoma 2wd and lowered it down a little?
Old 06-09-2014, 06:23 PM   #10
Got compression numbers?
Old 06-09-2014, 06:57 PM   #11
exileddeus
exileddeus's Avatar
Stock I think it's 11.5:1 I haven't tested it since the day I bought it though.
Old 06-09-2014, 07:00 PM   #12
exileddeus
exileddeus's Avatar
@Brett! That would be pretty cool, especially if you bagged it!
Low beams & High beams on together? Deathegg DIY / Maintenance / Service 26 12-22-2018 10:19 PM
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Bi-Xenon High Beams Not working YAR1S DIY / Maintenance / Service 14 12-24-2010 02:21 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
