Old 06-08-2014, 09:26 PM   #1
yak
yak
Drives: 2007 5 dr yaris
Rotor Removal Issue
G'day;
Rotors were toast, removed the first no prob...couple a smacks with a BFH, to break it free then installed two 8mm bolts (I use Seat Belt bolts with T40 head)
Moved to the other; side same process but, installed the bolts and the bloody rotor cracked across the hub face at both bolt holes...oh crap, now what ?
any help would be appreciated
cheers
yak
yak is offline   Reply With Quote
Old 06-08-2014, 09:53 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
like u said a big F@#$ hammer lol but if u have penetrating fluid spray some on the hub area also even tho the rotor is cracked i still would use the bolts to try and remove it ...anyhow at this point just swing away just dont hit the studs lol not the best thing for the bearing but looks like not much choice.
Old 06-08-2014, 10:52 PM   #3
A big puller would be safer for the bearing. I ran into the same problem a couple months ago helping a buddy do the brakes on his girlfriend's Mazda 3. We beat the snot out of it for about an hour with a 10lb sledge hammer. That was after heating it with a torch and nailing it with penetrating oil. Then, I remembered that I had a big enough puller, and that popped it right off.
Old 06-09-2014, 05:57 AM   #4
bronsin
bronsin's Avatar
Curse Toyota and its tight fitting in the center drums and rotors!
Old 06-09-2014, 11:58 AM   #5
yak
yak
Thanx for the imput fellas;
I took a time out ( the june bugs came along anyway) otherwise I'd
have probably done more damage in that frame o'mind...long story short,
BFH and careful aiming got the job done, mangled one of the chrome wheel knuts, nothin' a grinder didn't fix though
cheers
yak
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
