Old 06-09-2014, 08:15 PM   #1
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Transmission filter?
Hi all, Just thought I'd ask if any of you have had your Auto trans filter out? If so, is it a filter or a screen? Can it be cleaned or is it one time use?
Thanks.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 06-09-2014, 11:07 PM   #2
LugNut
Drives: 2007 2DR Liftback
Filter, not a screen. See my very recent post elsewhere in this forum, and many others' comments too. Use the correct fluid!
LugNut is offline   Reply With Quote
Old 06-09-2014, 11:53 PM   #3
UberSilver
UberSilver's Avatar
I tossed my oem filter last year when I changed it out. I only asked about it because I'm about to do the change for a friend, and she found a post somewhere about the filter being a screen that could be cleaned.
I never gave mine a close look. It's odd that Toyota charges $85. for the filter, but the WIX I installed in mine about a year back cost me $11. from rockauto.com.
I'm glad to hear I did not toss a cleanable OEM filter/screen.
Old 06-10-2014, 11:49 AM   #4
barryware
Make sure your "filter kit" (filter, o-ring, gasket), comes with a cork gasket not a rubber one.
Mine came with a rubber gasket. Cork is better in this application.
I did a drain & fill 1st. Then drove it for a few hundred miles, another drain, replace filter, and fill.
barryware is offline   Reply With Quote
Old 06-11-2014, 12:13 AM   #5
UberSilver
UberSilver's Avatar
I'll bite, why not the rubber gasket?
Old 06-11-2014, 01:05 PM   #6
barryware
Compresses too much. No feel for how tight the bolts are. Using a torque wrench I still ended up breaking one bolt. Bad bolt or crappy torque wrench.. Dunno. PITA though.
Your supposed to re-tighten / re-torque all the bolts after everything heats up with rubber. Not necessary with cork.
Old 06-11-2014, 09:08 PM   #7
UberSilver
UberSilver's Avatar
Thanks for the warning!
The rubber on mine has been good for the last year. I did use Toyota Black caulk on the pan side, and Low Strength Loctite 222 on the bolts.
Old 06-26-2014, 06:00 AM   #8
CB900F2
Drives: 08 Sedan
Changed out my auto filter last night and a lot messier then I was expecting. I used a Beck Arnley and it came with a rubber gasket.
So far so good. But I would have preferred cork also for the gasket.
I paid $17 for the kit, and I decided to give the dealership a call and see what they would have charged for the filter and gasket.. I was shocked!.. $145 for the filter, and $25 for the gasket.
CB900F2 is offline   Reply With Quote
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 12:09 AM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Installing a external in line transmission filter. YarisSedan Performance Modifications 1 03-31-2009 08:03 PM
