Old 06-10-2014, 09:16 AM   #1
C-max
Drives: 2007 Yaris T1
Installing alarm
good day
I bought alarm system that i have installed in my 2007 Yaris. What i wanted from this was to be able to lock and unlock the doors using the remote, it has a lock/unlock button between the driver and passenger seat just next to the handbrake lever. i managed to tap into the switch wires, it locks and unlocks using the remote but now the switch no longer works and i like to lock my doors wen am driving. now it requires me to arm the alarm to be able to lock the doors and since i will be inside driving the alarm will go off and i also taped in to the driver door switch wire to set the alarm off but the passenger door doesn't set the alarm off . Now my head lamp indicator on the dashboard not working and also when I open door with the lamps on there is no buzzing sound. I need to no where to tap wires to get my indicators flashing when arming or disarming the alarm. pleeeeaaase hlp am scared to tap any more wires
C-max is offline   Reply With Quote
Old 06-19-2014, 10:08 PM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Most alarms can be programed to lock the doors when you put it in drive, or turn on the engine. Or you can figure out what you did wrong. There may be a better way, like tapping into the main harness/fuse block.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 06-19-2014, 10:21 PM   #3
See my remote start and keyless entry wiring guide for door lock and light flash connection points. Make sure that the wires match in color and location before using them, as your European made Yaris may have some differences:
http://www.yarisworld.com/forums/showthread.php?t=24860
# diy alarm
Factory Alarm on my '08 Liftback is Too Sensitive! alex_melodymaker In Car Entertainment + Electronics (audio / video / alarm) 9 06-07-2011 03:21 PM
Alarm Wiring Advise Needed Lil Abner In Car Entertainment + Electronics (audio / video / alarm) 14 09-26-2010 10:11 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 09:18 PM
