Old 06-12-2014, 02:01 PM   #1
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
check engine code 0171 help
Hi this is the code i'm getting on my yaris. I changed the gas cap for a new one. changed the rubber hoses to new ones. took out the k&n filter, cleaned out the map sensor with contact cleaner, cleaned out the airbox and hoses. I put back the stock paper filter. Not sure what else it could be. Though it was the o2 sensor but my gas mileage is still very good around 615 to 640km per tank. it is only off about 10 to 20 km than usual. another weird thing is every so often the light will go out and the code is gone for a few days then comes back. Any ideas on what else it could be? also changed the pcv valve. the car has 329000km on it. Thanks
Adriaan is offline   Reply With Quote
Old 06-12-2014, 02:41 PM   #2
marauder
marauder's Avatar
Drives: '08 Yaris
Maybe this will help... http://www.obd-codes.com/p0171
Are you able to datalog? http://www.obd-codes.com/faq/fuel-trims.php
Maybe clogged fuel filter or injectors? Your MPG will be good if not better with a true lean condition... Have you ran a fuel system cleaner/treatment recently?
Also quite possibly the mention of exhaust leak between engine and first oxygen sensor, check for leaks at the manifold.
marauder is offline   Reply With Quote
Old 06-12-2014, 02:42 PM   #3
http://www.yarisworld.com/forums/showthread.php?t=26282
Doesn't looks like you have gone through he list of issues...
It could even be exhaust leak..
Old 06-12-2014, 07:28 PM   #4
Adriaan
In between cities
Adriaan's Avatar
thanks guys I didn't even thing of the fuel filter, I'll change it anyways couldn't hurt after all the mileage I've done. I'll also check the exhaust leak, as the other items you guys mention.
check engine code help snapgarrett DIY / Maintenance / Service 2 04-16-2014 12:33 AM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
