Old 06-17-2014, 04:38 PM   #1
GrayYaris
Drives: Gray
Is this the 5-4 converter harness I need?
I have a 2009 HB.
Will this work?
http://www.amazon.com/Hopkins-46155-...wiring+harness
GrayYaris is offline   Reply With Quote
Old 06-18-2014, 09:29 AM   #2
GrayYaris
Drives: Gray
Just need a yes or no. I have looked at old treads but just want to make sure that I don't fry anything here
Old 06-18-2014, 12:13 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Just putting in your vehicle on the web site says it doesn't fit...
this is what a search came back with that it said did fit. I am not saying you should go with this but more this is what I found. why not just search for "2009 yaris wiring harness towing" or similar?
http://www.amazon.com/Curt-56175-Con...wiring+harness
Old 06-18-2014, 01:43 PM   #4
Actually either of those would work fine with the Yaris.
Old 06-18-2014, 02:08 PM   #5
GrayYaris
Drives: Gray
Thanks for the confirmation. I don't like using Amazon's part search because it hasn't always been accurate for me. I was pretty sure all I needed was a simple 5-4 but wanted to be sure (and I'm running LEDs on the trailer so I shouldn't need battery power). Thanks for the help.
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 01:23 AM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
