Old 06-19-2014, 05:03 PM   #1
ssh4327
Drives: Toyota yaris
2008 yaris leaking water when a/c is on-not coming from pipe
I have a 2008 yaris that's been leaking lots of water on the passenger side of the car and a little from the driver side whenever the air conditioner is on. It's not coming from the pipe thing and I already tried clearing it out with a pipe cleaner. Also tried cleaning the area at the top of the dashboard. What is this and how can I fix it? Thanks I will upload a pic
ssh4327 is offline   Reply With Quote
Old 06-19-2014, 05:33 PM   #2
Your pic in your other thread shows the fan motor. If it is leaking there it is definitely the condensate drain that is backed up. You may just have so much gunk in the bottom of the air box that you didn't clear it when you tried before. Try blowing into the hose and see if you hear the water bubbling inside of the air box.
air conditioner, leak
Steps to install a subwoofer in Yaris 2008 HB eepp In Car Entertainment + Electronics (audio / video / alarm) 2 11-20-2013 07:30 PM
2008 Toyota Yaris passenger side view mirror change KOOCHO DIY / Maintenance / Service 1 12-01-2012 09:52 PM
