Old 06-20-2014, 01:34 AM   #1
travishv
Drives: 2007 Yaris hbk
Engine light + loss of throttle control
Just looking for some advice.
Ongoing engine light problem with my '07 Yaris 5 speed hatchback. 313,000km.
Engine light coming on every other day, sometimes with nothing noticeable happening , other times the car starts to hold the acceleration on it's own. So I take my foot off the peddle, and the car holds that level of acceleration (no the peddle isn't stuck on a mat). If I push the clutch in, the Rpms slowly increase. I turn off the car , turn it back on, engine light stays but the gas peddle responds normally again.
I took it to the dealership and they retrieved the codes:
P0011 - camshaft position 'A' timing over advanced, or system performance. (This code started coming on a year ago and was chalked up to the sensor being dirty from a time when I had to leave the car 6 months unused.
C1541 - vehicle speed sensor
V0105 - Lost communication with fuel injector control module.
They said they could not provide a diagnosis, cleared the codes and told me to let them know if it comes on again. Of course just as I was driving home it came on again.
Any ideas what could be going on? And why with the codes a diagnosis wouldn't've been able to be made.
Thanks!
travishv is offline   Reply With Quote
Old 06-20-2014, 06:09 AM   #2
With the V0105 code, I would suspect the ECM to be the issue. You might want to remove it and pop the cover on it to see if there is corrosion on the circuit board.
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? zimso General Yaris / Vitz Discussion 3 10-19-2010 07:17 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
