Old 06-22-2014, 04:22 AM   #1
yrx2006
Drives: 2006 toyota yaris yrx
1.5l camshaft position sensor
hi everyone, Im new to Yaris world and was just wondering if anyone knows how to test the camshaft position sensor on a 2006 Yaris. I have a problem with the car starting and cutting out, I have checked coils, spark plugs, crank angle sensor, fuel pump and injectors and this is the last thing I can think of checking. I just need to know what ohm you should be getting when testing the camshaft sensor. I did a test while trying to start the car and got a reading of .1 to .3v while car was cranking is this within spec? any help would be greatly appreciated.
yrx2006 is offline   Reply With Quote
Old 06-26-2014, 05:29 AM   #2
yrx2006
I have tried that too and still nothing just need the specs on voltage and ohms on the camshaft position sensor
camshaft, sensor
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 06:12 AM
crank position sensor leaking kou DIY / Maintenance / Service 0 02-24-2012 07:01 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
