Old 06-24-2014, 05:55 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Need help guys headlight won't shut off!!!!!
Weird issue I had today..did look at one previous post which didn't help . Already disconnected battery for half hour and also tapped on relays underneath the steering and still no solution.. Seems like it's stuck on on. Now I can use high beam by pulling the level but high beam by pushing the lever won't work unless it's in on ON position... I'm lost...this leaves the actual switch issue.. Thanks
So far I've done..
1. Disconnect battery atleast half hour and reconnect
2. Check h-lp/amt relay located on the engine compartment passenger side, and this does not shut off the light even when it's unplugged..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 06-24-2014, 05:55 PM   #2
marcus
toyota
marcus's Avatar
Could be the actual relay which I'm trying to figure out where it's at...
Old 06-24-2014, 06:23 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
DLR maybe the problem ...under the steering column unplug it and see , or like u said relay .
Old 06-24-2014, 06:26 PM   #4
Besides the DRL module, check the relays in the little box on the right side of the engine. Pull each out and give it a good whack against a hard surface to free the contacts if they are stuck.
Old 06-24-2014, 06:34 PM   #5
marcus
toyota
marcus's Avatar
I had drl unplugged 5 years back.. Trying to figure out where the relay is it's not on the fuse box on the engine bay..
Old 06-24-2014, 06:59 PM   #6
marcus
toyota
marcus's Avatar
No luck...can't believe no one out there had this issue... First time World Wide Web can't help... This is one for the books...lol
Atleast this doesn't keep the park light on just the headlight so switch still works to turn the park light on ....so weird..I hate weird..
Old 06-25-2014, 07:53 AM   #7
marcus
toyota
marcus's Avatar
Bumpin.....
Old 06-25-2014, 08:04 AM   #8
I can't follow your issue by reading this.
Are you saying you are currently in a situation where the only way to turn lights off is to disconnect the battery?
Old 06-25-2014, 08:14 AM   #9
marcus
toyota
marcus's Avatar
Yes.... I actually just took off the 2 fuse for left and right so I can still use the car for now... But the headlight is stuck to on.. Park light , for lights I can still turn on and off..
Old 06-25-2014, 09:53 AM   #10
marcus
toyota
marcus's Avatar
Disconnect the relay on the engine bay passenger side h-lp/amt relay and that doesn't even shut off the lights...��
Old 06-25-2014, 11:12 AM   #11
That's fun. Sounds like you have a short somewhere!
Old 06-25-2014, 01:49 PM   #12
marcus
toyota
marcus's Avatar
Could be the actual switch but there shouldn't be any short circuit anywhere I don't think ...sigh... I'll unplug the switch and see if it goes off.. Update tomorrow..
Old 06-25-2014, 02:50 PM   #13
How many days can you keep this running? Lol
Old 06-25-2014, 04:06 PM   #14
marcus
toyota
marcus's Avatar
This is only the 2nd day..this will be running till it's fixed..
Old 06-25-2014, 06:22 PM   #15
If pulling the relay did not work, check the wires at the headlight connectors. Constant power is present and the ground is switched to the high or low filament to turn them on. If the switched ground wire is damaged on one side it would cause them to stay on.
Old 06-25-2014, 07:32 PM   #16
Good call Scott as he has recently done a projector retrofit.
Old 06-25-2014, 09:23 PM   #17
marcus
toyota
marcus's Avatar
Ok I'll check the headlight wirings..although the retro fit was done dec 31st why now.. Hope it's the wiring.. I was shooting to check the switch itself and the drl relay box.. Thanks guys appreciate the input I'll work on it tomorrow!!
Old 06-26-2014, 12:59 PM   #18
marcus
toyota
marcus's Avatar
It's FIXED.. guest what caused it... It's kinna stupid .. No issues with headlight wires, or fuses or relay, not even the switch. My last hunch is what did it.. Still thanks for the guidance fellow yaris owners....
Oh yeah it's the blue wire from the drl relay that I unplugged and taped.. Took over 5 years for the tape to fall off that exposed the wire onto the yaris body which is keeping the headlight on the whole time..
Pls close thread mods.. Thanks again guys..
Where can I order a Headlight Bulb Rubber Boot online? JAM DIY / Maintenance / Service 2 12-08-2011 06:48 PM
calling all yaris guys , need your help please aucorium General Yaris / Vitz Discussion 15 07-07-2011 02:28 AM
LV guys! pinoypizzaboy Southwest 2 03-13-2009 02:13 AM
how it went the reunion, up load your pic guys !!!!!!! yoxx New England 0 11-24-2008 05:22 PM
