#1 |
![]() Drives: 2002 Echo 4DR Sedan 5SP Join Date: Dec 2013
G'day All,
Looking for some serious help with my 2002 Toyota Echo. I can't really afford over $100 per hour to have the dealer diagnose the issue. I've got a 2002 Toyota Echo with 135 000 KMS. Three weeks ago the engine light came on. Using my Ultra Gauge I retrieved the following notorious codes P0440, P0441, P0446. After hours of reading I figured the charcoal canister needed to be replaced at some point in time. Many people report having these codes/engine light on for years without issue. Then 2 days ago I went to fuel up and the gas pump would just click off after only pumping about half a litre of gas. It just kept clicking off. This is a major issue because if I can't fuel the car, then it's useless, lol. I love the car, it gets babied, and returns 50MPG to me! So, is this refueling issue also related to the canister? The weather was very hot and humid when I tried to fuel the car so I am wondering if that may contribute? I tried refueling at a couple different stations and no change. The weather is still very hot and humid though. I have checked alllllll the EVAP connections on the canister under the car. Check for spider webs, blew compressed air through all the lines, checked the VSV on the intake, inspected those lines, inspected the fuel filler neck and could not find any holes or leaks. Does anyone have any other suggestions? I'd hate to buy a canister, $400+, to still have a refueling problem. |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
don't top off
BTW, do you top off your tank?? That will kill your charcoal canister. First click, stop and go on your way. IF you are not comfortable replacing your canister yourself, check with an independent garage.
#3 | |
I've owned the car for 6 months and 10 000kms and YES I have over filled the tank a good number of times. I am comfortable changing the canister except for that one skinny tube with a plastic connector, I can't seem to disconnect when I was doing my troubleshooting. Do you know how to disconnect this tube?
#4 |
I just installed a used charcoal canister and I can now fuel the car without the pump clicking off. Thanks for all the help!
BTW does anyone know how to properly remove the clip circled above? |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
