Old 07-04-2014, 08:13 PM   #1
R3DN1NJ4
Drives: Toyota Yaris Sedan NCP93R
320km per tank economy
Hello all,
I'm trying to find the reason of such a bad fuel economy in my 2008 yaris sedan, AT,1.5 L, 105000 km.
That should be around 18-19 mpg...
i have:
* cleaned throttle body
* cleaned MAF sensor
* cleaned PCV valve and hose (had lots of gunk and was stuck, it now rattles a lot when shaken)
* changed ATF
* changed spark plugs (NGK BKR5EIX)
* checked drum brakes
* checked for error codes with OBDII and torque app.
* checked coolant temp (averages 85 °C / 184 °F)
The car is really responsive, speeds up fast, starts like new.
i have also a couple questions.
01. Does yaris have an EGR valve?
02. How to check o2 sensor? can i test with multimeter ?
03. What else could be the culprit? Catalytic converter? fuel injectors? coils?
04. Where can I find sensor reading threshold to compare ?
thanks
UPDATES:
07/12/14 - Changed B1S2 O2 Sensor.
07/23/14 - Cleaned spark plug well (had oil) scanned B1S2 voltage, still 0v.
07/25/14 - Changed valve cover gasket and spark plugs for Denso SK16R11.
R3DN1NJ4 is offline   Reply With Quote
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 04:57 PM
Longest Distance on One Tank: 1626 miles! Yar Is Word Off-topic / Other Cars / Everything else Discussions 0 06-21-2012 10:44 PM
I can never fill my tank completely? yarisitis Fuel Economy Forum 9 12-06-2010 12:51 AM
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 09:04 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 03:35 PM
