Old 07-10-2014, 11:58 PM   #1
Link91
Drives: 2004 echo RS
Will these fit?
I found a smoking deal on some tires and rims todays in the local adds, and I was wondering if they would fit or if they would rub on my 04 RS.
Tire Size are 205/45/16
4X100
My car is not lowered.
Thanks
Link91 is offline   Reply With Quote
Old 07-11-2014, 02:01 AM   #2
mutitasd
Drives: Toyota Yaris AT S limited 2008
according to my personal experience it will fit, but there will be some gap between the tire and fender though.
mutitasd is offline   Reply With Quote
Old 07-11-2014, 09:29 AM   #3
Link91
Would this be because the car is not lowered? But would be fixed if it was?
Thanks again
Old 07-11-2014, 09:43 AM   #4
what gap? the gap will be the same with this 16''... about 7mm larger in diameter, and 1.3% variance on the speed. I'd say go for it as long as the offset is between 32ish and 45 and rims no larger than 7''
http://www.1010tires.com/Tools/Tire-...5R16/205-45R16
Old 07-11-2014, 11:32 AM   #5
You don't say the size of the wheel or the offset. Those are important details. In general, without the car lowered you should be just fine with that. I ran 205/50/16 and had minimal rubbing on a lowered car.
Old 07-15-2014, 01:12 PM   #6
marion2
Drives: Yaris Sedan YRS
16x7 4x100 offset 42 wrap on 205/45/16 and I might use Df210? With an inch lifter at the back will there be a rub on a Yaris sedan?
marion2 is offline   Reply With Quote
Old 07-18-2014, 09:35 AM   #7
Jevgeni
Don't want to start a new topic. Just a quick question: will 185/65/16 wheels fit on stock 2008 yaris hatchback? Thanks.
Jevgeni is offline   Reply With Quote
Old 07-18-2014, 02:20 PM   #8
That's a tire size, and it's a little tall, but yes
Old 07-18-2014, 02:21 PM   #9
This will work, but 205/50/16 is the correct overall diameter, so you'll be just a bit short.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
