Old 07-18-2014, 08:26 PM   #1
sheekeebut
Minimalist
Drives: 07 silver sedan
Suspension geometry & cornering/handling
This is for all you engineering specialists and track goers.
I've just lowered my sedan on Tein Street Basis coilovers, with what measures out to a 1.5" (38 mm) drop. Last week I checked under the car, and my front lower control arm height measures .70" (20 mm) lower at the inner bushing than at the ball joint. Therefore the arm points slightly upwards.
I know that this lengthens roll couple and lowers roll center, especially if the strut is straight up in terms of lateral angle. At the same time, I'm a little worried about it fudging up my camber movement(?) at spirited road twists.
So the questions:
1) Is the Yaris front strut angled laterally (logically inwards?) in any way? How much?
2) What ride height do you track goers tend to go for your overall cornering performance? Calculated and numerical data gathered for tuning, or just seat of your pants tuning?
3) What does a low or even below-ground roll center "feel" like at corners and bumps?
4) Short of getting adjustable ball joints and steering linkages, do I have to raise the ride height a bit (18 mm if struts straight up?) to get back to a lower-control-arm-to-strut angle of 90° or less to optimize performance? As in, does going over 90° mean having already gone beyond good camber and roll center characteristics?
5) Am I overthinking this?
sheekeebut is offline   Reply With Quote
Old 07-27-2014, 01:05 PM   #2
sheekeebut
Minimalist
A week and a half, and no one's interested in answering any of the questions? Feels worse than just getting full-on flamed..
Old 07-28-2014, 02:31 AM   #3
eablola69
Drives: 2007 Yaris 4-door Hatch
#5, yes you might be over thinking it.
eablola69 is offline   Reply With Quote
Old 07-28-2014, 08:42 AM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
As flimsy as the lower control arm is, if you trow it into a corner too hard....the lower arm is probably going to deflect and your alignment settings are for refernce only.
Old 07-29-2014, 09:10 AM   #5
yes, over lowering the car will have negative impact on the camber geometry to a certain extant. But at 1.5" you shouldn't have much issues. The angle between the control arm and the strut is still probably less than 90°.
Old 07-29-2014, 06:38 PM   #6
Rigaud
Drives: 2009 Yaris
What about dropped say 2" or 2.5"?
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-29-2014, 06:39 PM   #7
I don't know. I don't have a Yaris.
Old 07-29-2014, 08:22 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Mines lowered 1.75~ and it handles awesome...however the ride is not so great
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-30-2014, 03:13 PM   #9
sheekeebut
Minimalist
Thanks for the feedback!
Old 08-09-2014, 05:17 PM   #10
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
(1) Did you mean Steering Axis Inclination angle?
If so, then it is 11.30 degrees.
Mittelklasse is offline   Reply With Quote
Old 08-10-2014, 02:49 AM   #11
sheekeebut
Minimalist
Thank YOU Troll-Face-Avatar. You good sir (madame?) have just given me my next topic of research... And in comprehensively answering 1), you have given me the means to answer question 4) objectively.
After soon trying out a slammed-silly civic sedan, I may find my own answer to 3).
All that remains is 2). I think only two practical ways to get this:
Find people who race with coilovers.
Or
Start going to the track.
Hmm..
Old 08-10-2014, 08:22 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I race with coil overs. I have -2.5 camber up front. I lowered mine I believe 2.5-3 inches. I do not know exactly. I run megan coil overs witha 15x7 rim with 225-45 Hankook RS3 tires.
All my adjusting I have done has been how the car feels to me. I like my rear very loose. My tire pressures are 40psi in front and 55psi. This is for autocross. On track days, I drop it to 28psi front and 45psi in the back because the tires get A LOT hotter for longer periods of time.
If you look at my times here:
http://www.buccaneerregion.com/ce-7-14.html
This was my last event. It was a pretty fast event. I do not own a gopro, so I don't have any video of the course. If you are really wanna see how the course was layed out I can link a video for you. I killed the RAW time and Took 1st in Pax.
Each driver is different though. You need to play around with your settings on how you drive. What works for one person on the same car, may not work for another person.
-Derrick-
Old 08-10-2014, 07:27 PM   #13
sheekeebut
Minimalist
And with ilikerice's answer, thread has been concluded. Thanks all. If I remember, I'll add to this thread by describing my crazy low driving experience.
Old 08-12-2014, 01:38 AM   #14
^ Oh?
ok, I won't post then.
Old 08-12-2014, 03:16 AM   #15
sheekeebut
Minimalist
Oh, Garm over here holding out on me! Please, share some racing knowledge with the poor folk.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Confort suspension for TS? shtou Yaris TS Talk 0 06-16-2011 01:27 AM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Tein Basic Compact Suspension for SALE!! 33lam Australia 14 04-17-2010 08:24 PM
