#1 |
![]() Drives: 2007 Toyota Yaris Join Date: Jul 2014
New to the forum
Hi all,
I have just joined this forum. I just wanted to introduce myself. I have an 07 yaris 2 door hatchback which I purchased in February 2014. The car has been running fine for me with no problems so far. There is just one thing that I am looking to find a solution too which is to at least have power locks or should i say (Keyless entry). Everything is completely manual in the car. I have looked into the DIY section and have seen some good discussions on this topic. I see that there are many after market kits available. I was wondering if I could be provided with some guidance as to which kit could work for my car as I have seen that some kits work for the cars that have at least power lock system in them already. I am sorry if I posted this question in the wrong section. Overall, any suggestions will be highly appreciated. Thanks in advance. |
Welcome.
I have installed kits in two Yaris and the aftermarket kits are definitely the most reasonable option. Avoid cheap kits, as I tried one cheap ebay power window kit and the actuator lasted less than a year. a1-electric.com sells much better quality kits and supports what they sell. The a1 lock and window kits that I used have been excellent. For the windows, the other option is to track down a set of OEM motors and regulators (the scissor lift that sits inside the door). When my ebay kit failed, I switched to OEM motors/regulators and they work perfectly. They can easily be tied to the aftermarket relay unit, so doing a hybrid OEM and aftermarket kit is very doable. The same holds true for power locks. The problem though is that for 3 door Yaris the OEM power window regulators are hard to find.
#3 |
CTScott, thank you for all the information. So the kit at " http://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=AEOS&Product_C ode=W01C-712T" should work ok for my car ? One thing I want to mention here is that my car dosent even have central power locking system. There is no switch inside the car to lock/unlock it from inside. I hope this kit is going to work for my car and is not too difficult to install.
I think I am only going to go with the power locks for now, it will make things much easier, specially in winter when locks get all frozen. It'll be nice to have power windows also though. May be some time later. |
#4 |
Thank you CTScott for the information. Sorry for a delayed reply. I actually did reply to your message earlier but for some reason it never got posted. Anyways so the kit at “a1-electric.com” should work ok for my car for power locks ? I have read in one of the forums that some people who used those kits already had some central locking system in their cars where they could lock/unlock from inside. In my case, everything is completely manual without any central locking system. I hope that kit is going to work for me. Also, I hope its simple enough to do it urself .
#5 | |
It is a DIYable thing from my experience.
#6 |
Thank you CTScott for the information . I will order the kit and will install it myself.
| Back to the forum! | wiirenet | Off-topic / Other Cars / Everything else Discussions | 5 | 03-02-2012 08:18 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Forum Conduct | ChinoCharles | Suggestions - Feedback - Questions | 60 | 09-11-2009 03:41 PM |
| Forum to discuss with Japanese Car enthusiasts | castle22 | Off-topic / Other Cars / Everything else Discussions | 0 | 03-13-2007 09:31 PM |
